Thread: 2004 Y20DTH headlights, instrumt lights, radio, airco,.. flickering !
    Jun 2009
    Belgium
    Default 2004 Y20DTH headlights, instrumt lights, radio, airco,.. flickering !
    Dear Vectra-c users,
    I have (again) a big problem with my 2004 Vectra-c 2.0DTI.
    Everything flickers
    When I start my car or when I'm driving, everything flickers at the same time.
    So it happens that my headlights start to dim, also the lights in the middle console, the radio just stops working, and the airco shuts down. It doesn't last long. So far the headlights didn't dim completely, luckily
    For the moment, one dim light is dead.
    I've read out the car and it carry's fault code:
    B2652-05 Instrument dimming bulb output circuit open or low voltage
    As everything is failing I probably suspect some main relay that has a bad contact maybe? What do you guys think?
    Thanks in advance,
    Glasgow
    Sounds like your alternator is failing.
    Agreed, sounds like either the alternator reaching the end of its life or the auxiliary belt needs replaced
    Does the battery warning light flicker or come on?
    Jun 2009
    Belgium
    Nope, no battery warnings. I've monitored the battery voltage during riding, and it is at a steady 13.1V.
    wirral
    33 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Voltage is to low. Alt needs changing
    Agreed, the car is running straight off the battery, so it won't last long
    On the plus side it is a diesel, so there won't be much drain once the engine is running
    However on starting (especially in the cold) will drain the battery whilst the glowplugs operate
    Jun 2009
    Belgium
    Ahaaaa !
    Found it !
    When I was changing the dim light, my ears noticed a hissing sound coming from underneath the battery warpping...
    Somehow, the bolt that bolted the mass cable to the battery connector has loosened a bit. As I can see from the battery wrapping, there was a little fire there... I've fastened the bolt now. I think the problem is solved now
    Anyhow,
    lots of thanks for the input !!
  1. Flickering Headlights
    By erni3wi5e in forum Bodywork & Interior
    Last Post: 9th March 2012, 16:57
  2. Headlights flickering ???
    By digitalinkjetman in forum Electrical & ICE (including SatNav)
    Last Post: 3rd November 2011, 11:49
  3. flickering headlights??
    By dog in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2011, 21:35
  4. Y20DTH 2.0 DTI 2004 Vectra - Increase BHP?
    By Leviathan in forum Tuning
    Last Post: 23rd September 2008, 23:00
  5. Flickering Headlights
    By exclusive07 in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2007, 20:39
