Thread: DAB CDC-40 Or Not
    Regular Member stanian's Avatar
    Stafford, Midlands
    Trim : GSI
    Engine : 3.2
    Mileage : 45000
    Default DAB CDC-40 Or Not
    Does anyone know if the CDC-40 is the same unit with or without DAB, I had to have mine replaced under warranty due to the cd multi changer not drawing in cd's and when it came back there was no DAB in the menu just FM AM CD and Sound.
    If it is the same does the DAB need to be plugged in or enabled somehow?
    Thanks.
    Regular Member willc01's Avatar
    UK Motorway Network + some smaller roads
    I have the cdc40 Opera unit with DAB. Is yours the Opera? Could be that the unit has been exchanged and has come from another european market where DAB is not available.
    I would imagine it either has it or it doesn't and can't be programmed. Can someone contradict me?
    Stafford, Midlands
    Trim : GSI
    Engine : 3.2
    Mileage : 45000
    Yes, it is the CDC-40 opera, I read somewhere on here that the DAB reciver is under the drivers dash, that is the reason I asked if it was the same unit . I also read that the DAB has a seperate ariel mine has a much larger mount for the ariel than standard.
    Guess I need to go back to the dealer and get them to order me the right unit.
    Feb 2006
    Dorset
    The units are the same , it needs tech2 to enable DAB ,
    Stafford, Midlands
    Trim : GSI
    Engine : 3.2
    Mileage : 45000
    That's Brilliant I'll get it done tomorrow.
    Thanx
    Stafford, Midlands
    Trim : GSI
    Engine : 3.2
    Mileage : 45000
    DAB working fine re enabled at dealer all ok now.
