Results 1 to 10 of 18
Thread: Urgent Vectra Spanner help
    Regular Member Thom's Avatar
    Nov 2010
    UK
    Default Urgent Vectra Spanner help
    Hi guys, i need some really major help now as my cars getting stupid to drive.
    Vectra 2.0 DTI 2003 100k miles
    I cleaned the inlet and egr etc over the summer and since had problems with a limp mode/spanner light coming on.
    It only comes on when the car is under load trying to accelerate for a decent length of time, there is one road i use in Wales to Aberystwyth where it is a long uphill dual carriageway where it always comes on trying to maintain 60mph in 5th gear.
    All turbos hoses appear okay, and one has recently been replaced for a silicon - Can anyone advice?
    Its getting to the point where i want rid of it now.
    Thom
    Admin plasma's Avatar
    On the Forum
    217 Post(s)
    Engine : 150
    Mileage : 74000
    have you had the codes read to tell you whats wrong with it?
    no point blindy guessing as to faults
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Nov 2010
    UK
    I did have a list of codes i produced myself however im not sure how accurate it was, ill clear it tomorrow and re-read after a drive.
    Thom
    Wirral, UK
    Vehicle : Meriva B
    Trim : SE
    Engine : 1.7CDTi
    Year : 2011
    Reading the codes and posting full information is a good idea, that will help.
    But it could either be the catalytic Converter in the exhaust is full of soot or the turbo packing up.
    The cat can be bashed out, (possible MOT problems next year, hope not) and the turbo is £200 to £300 to put right. Not good.
    Nov 2010
    UK
    If it helps, just before the spanner comes on the car feels like its lacking power, and sometimes begins to decelerate ever so slightly. It may also be in my mind but it feels like the revs 'wobble' a tiny amount just before limp mode kicks in.
    Im a novice to fault codes, will these show up my problem?
    Nov 2010
    UK
    B3794 - Switch Cruise Control Circuit Open or High Voltage
    (04) - Present
    B2810 - Steering Wheel Remote Circuit Open or High Voltage
    (04) - Present
    P0234 - Boost Pressure Control Circuit Negative Deviation
    (5A) - Present
    U2107 - Invalid Data from BCM (Body Control Module)
    (71) - Present
    B2996 - Rear Left Door Switch Circuit Open or High Voltage
    (05) - Present
    B3974 - Driver Door Select Switch Window Lifter Circuit Open or High Voltage
    (05) - Present
    Heres my fault codes - any further help available going by these?
    wirral
    31 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Clean the boost sensor
    Nov 2010
    UK
    How likely is it that that is the problem because i had cleaned it when i had the inlet apart?
    Could i have damaged it?
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    How did you clean it?
    Nov 2010
    UK
    I cleaned it with Carb cleaner and nothing else.
    Ive cleaned it again an hour ago and checked all the hoses and connections once more.
    It wasnt particularly dirty and free moving.
  1. Urgent problems with Vectra
    By pacifica112 in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2011, 21:59
  2. Vectra 2004 ls dti spanner light help!!
    By jediknight in forum Vectra C / Signum Car Chat
    Last Post: 15th September 2009, 09:44
  3. Vectra c 2.0 DTI car and spanner light on
    By kman247 in forum Introduce yourself.
    Last Post: 20th December 2008, 19:26
  4. Urgent Help Cant Lock My Vectra
    By mickontherun in forum Vectra C / Signum Car Chat
    Last Post: 18th October 2007, 20:32
  5. Urgent or not so urgent ?? Service Warning Light
    By martinh67 in forum Electrical & ICE (including SatNav)
    Last Post: 26th July 2007, 09:54
