Results 1 to 10 of 15
Thread: Dip-Beam Lights - Both stopped working
    Buxton, Derbyshire
    Default Dip-Beam Lights - Both stopped working
    The car is a 53-plate pre-face Active.
    It's got standard halogens for both dipped and full beam.
    The problem is neither dip bulbs come on, though side-lights and main beam all work.
    The bulb warning light was already on as one of the rear lights blew a while ago (Never bothered with it as there's another one on that side that does work).
    I changed one of the bulbs, didn't do anything, I also checked and swapped the fuse in F8 under the bonnet, no difference.
    What could be the cause of this? We're starting to wander if there's an issue with the switch unit.
    Is there a control unit that could be faulty...?
    This is really annoying as the car can't really be driven at night now. They went when my dad was out so he had to finish the journey blinding people...
    Nov 2009
    N/A
    I'd check the relay first, I'm not sure which relay the headlamps use, sure someone with a haynes manual to hand could tell you
    Buxton, Derbyshire
    Gah! Relay, of course... Will investigate. I'm sure someone knows which relay it is......?
    Nov 2009
    N/A
    If I was still at Uni, I'd have my Haynes with me and be able to tell you!!! (Just noticed your in Buxton too so I'd prob be able to help as well!!!!)
    Regular Member Jonsey's Avatar
    Oct 2010
    Walkden, Manchester
    Just looking at my haynes manual atm but I can not see any relay for the headlights.
    Oct 2010
    Walkden, Manchester
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    To eliminate the switch disconnect it. The headlights should come on permanantly with the switch disconnected
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Have you tried changing a bulb for a known good one? Had both mine blow within one minute of each other once!
    Also, check voltage at the bulb with a multi meter
    Buxton, Derbyshire
    Thanks for those, I'll try the switch in the morning.
    In that diagram what are items 2, 28 and 29 and where are they located?
    Mungo, where can I get a relay locally if that's what I need? Would SDL or G&T do them...?
    Buxton, Derbyshire
    Quote Originally Posted by tony-1977 View Post
    I changed the bulb one side with a brand new one. Both went at exactly the same time, seems a bit suspect for me both going at exactly the same time...
    If there's a short, I'll be sad... No experience with can-bus wiring...
  1. Sub has stopped working
    By inchy1981 in forum Electrical & ICE (including SatNav)
    Last Post: 7th December 2012, 16:35
  2. Right my hid stopped working
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2011, 15:22
  3. Fan stopped working
    By andyxedos in forum Troubleshooting
    Last Post: 23rd December 2009, 23:18
  4. brake lights stopped working
    By peadar in forum Electrical & ICE (including SatNav)
    Last Post: 13th November 2008, 21:57
  5. brake lights stopped working
    By peadar in forum Handling & Braking
    Last Post: 6th October 2008, 07:22
