Thread: Engine cover rubber grommets
    Worksop
    Default Engine cover rubber grommets
    Mine ave split and can't put engine cover back on without em can u buy em? As the bolts just fall thro middle without em
    Aug 2010
    Leeds
    Vauxhall dealer open till 12 parts counter today.
    Regular Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    For the Z19DT (8 valve) it is either
    24453627 - STUD, 9.9 MM DIA., COVER TO CYLINDER HEAD
    or
    90412865 - BUSH, CYLINDER HEAD COVER CAP
    Think the BUSH is for the front of the cover that the bolt goes through....
    __________________________________________________ _____________________
    For the Z19DTH (16 valve)
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Nice one mate but he has a z20 net lol
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    Quote Originally Posted by paulvectrac View Post
    in that case then the rubbers are not available as a seperate part,you have to buy a new cover
    Regular Member Vectra Meldrew's Avatar
    Hertfordshire
    oops, read it too quickly thought it was for a cdti
    Regular Member 11mallard's Avatar
    Dec 2010
    Selsdon,Surrey
    I've got a 1.8 and mine split. Went to breakers yesterday as I need a few bits and found some on an Astra and a Vectra that were perfect.Total cost for Cam sensor plug and wire, Interior Rear Light and ribbon wire, cover gromets and brass inserts for engine cover and a Drivers Door window/boot lock/mirror adjuster control unit all for £10.
    Don't buy a cover go to a good breakers.
  1. Engine Cover Rubber Mounts
    By Grahamy in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2011, 21:24
  2. 8v engine cover screws\rubber grommets
    By sfs in forum Vectra C / Signum Car Chat
    Last Post: 24th June 2010, 12:50
vauxhall zaofira engine cover bolts
vauxhall vectra ctdi engine cover rubber mounts
vauxhall vectra engine cover rubber inserts
vauxhall vectra cdti engine cover rubber mounts
vauxhall corsa engine cover grommets
vectra plastic engine cover gromets
put engine cover back on astra
zafira Engine cover rubber mount
where can i get rubber grommets for my vauxhall engine cover
zafira plastic engine cover rubber
