Results 1 to 10 of 11
Thread: Induction Kit question!
    South Yorkshire
    Default Induction Kit question!
    Hi guys,
    I need an induction kit to compliment my Spider Box wich should arrive this week. Can anyone recommend a particular box and give me a link to where I can purchase one from.
    Cheers for your help
    South Yorkshire
    Please help guys. Need some info on a decent induction kit. Want to sort one out before end of the week.
    have you thought about a panel filter?? just as good for flow, but less obtrusive noise??
    Regular Member Spikeyİ's Avatar
    Dec 2005
    In the sponge-monkey tent
    As it happens, if you're after a K&N 57i type kit, I might be able to help you out. That's the full on open cone filter type, not the replacement air filter that fits in the cars airbox.
    had this (http://forum.vectra-c.com/showthread.php?t=4358) fitted on my old vec-c (now my bruvs car ,Pioneer)....
    South Central England
    13 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Stick with the air box mate, mine produces so much flow that the ECU complains that the mass air flow sensor is knackered. Just change the filter often, remove the internal cone and add a second cold air feed.
    Regular Member Robbieben's Avatar
    Dec 2005
    Polishing a car somewhere
    As Mark says, a panel filter in the standard airbox, with the airbox mod done will provide more than enough airflow for your needs.
    Try
    www.courteneysport.co.uk
    their panel filters are excellent, better filtration than a k&n but less restrictive than a standard paper element.
    Regular Member The Doc's Avatar
    'Norf Yorks.
    Avoid induction kits and panel filters IMO and just replace the paper one frequently. Much better flow that way.....
    Dec 2005
    Quote Originally Posted by nutron View Post
    Mate, that's not really suprising as you have 3 pipes bypassing the MAF sensor, it's probably only registering half the air it should and screwing up your air/fuel mixture. Hence all the black smoke we saw at the Pod?!?
    lol............................................... .................................................. ..
  1. K&N Apollo CIS Universal Induction Kit vs. K&N 57i Induction Kit
    By LAZZEE RARSE in forum Petrol Engine related
    Last Post: 26th July 2010, 22:13
  2. induction question
    By john-d in forum Petrol Engine related
    Last Post: 10th December 2009, 20:58
  3. induction kit
    By bertbuckie1 in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2009, 04:13
  4. induction
    By lozza-3.2v6 in forum Petrol Engine related
    Last Post: 24th February 2008, 17:56
  5. induction kit is on and wow
    By big phil in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2006, 00:54
