Thread: rear discs
    Aug 2010
    york
    Default rear discs
    hi trying to find how 2 for replacing rear discs and pads vectra c sri
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    You'll need a rewind tool to wind piston in on rear calipers mate.
    also a 7mm Allen key.
    And a think the caliper carrier bolt is e40 but sure someone will correct me.
    Sure there will be a how 2 on it in the how 2 section.
    But easy enough.
    Jack up (chocking front wheels an ensure hand brake is off)
    Remove wheels
    Remove caliper retaining spring
    Remove disc retaining bolts at this point as makes life easier if it's stuck.
    7mm Allen key remove sliders ( behind rubber bung on caliper)
    Tie caliper up out the way
    Remove carrier (e40 a think)
    Remove an replace disc
    Refit carrier remembering thread lock
    Wind piston back on caliper
    Fit new pads
    Clean an apply thin layer of grease to sliders
    Refit an refit retaining spring
    Refit wheels
    Pump foot brake until hard keep applied then apply handbrake
    Job done
    Aug 2010
    york
    Thanks for info,looked on how 2 section but couldn't find one
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Aug 2010
    york
    CHEERS gunna do them in morn
    Aug 2010
    Leeds
    Nice list.
    Just one thing you forgot a pair of axle stands please don't fit them off the jack.!
  1. rear discs
    By marc vectra sri in forum Suspension, Wheels & Brakes
    Last Post: 27th September 2011, 20:27
  2. rear discs
    By kevchall in forum Suspension, Wheels & Brakes
    Last Post: 9th April 2011, 22:49
  3. rear discs
    By niicckk in forum Handling & Braking
    Last Post: 6th September 2010, 23:14
  4. Rear discs
    By stuk2000 in forum Suspension, Wheels & Brakes
    Last Post: 13th June 2009, 18:25
