Thread: M G ZR Noise
    Regular Member crispy007's Avatar
    Oct 2010
    lincs
    Default M G ZR Noise
    hi all
    need a bit of help with the wifes mgzr the near side rear wheel is making a grinding/wearing noise
    we have driven it along and put the brakes on no difference is made to the noise
    so i thought it might be the wheel bearings but it has done 30 miles today in foul weather (lots of water about) and it does seem quieter but it is still there
    can you get to the wheel bearings (to grease or oil them)easy or is it a garage job
    any help is gratfully recieved
    thanks simon
    Oct 2011
    Essex
    My 25 had rear drums - has the ZR? Whip the drum off see if the shoes are in one piece/delaminated?
    East Ayrshire
    Trim : SRI XP1
    Might seem like a strange question, but have you painted your brakes?
    Oct 2010
    lincs
    Quote Originally Posted by stevie16v View Post
    no we havnt would that make a difference noise wise
    Oct 2010
    lincs
    Quote Originally Posted by andrew e View Post
    yes it has drums but putting the brakes on makes no difference to the noise
    i was thinking more on the lines of dryed out bearings
    East Ayrshire
    Trim : SRI XP1
    Quote Originally Posted by crispy007 View Post
    I had it on an mg zs I had a few years ago. Turned out it was that. Obviously not the problem you're having tho
    Hope you get it sorted bud
    Dec 2011
    Grangemouth Scotland
    Does the car have discs or drums on the rear??
    Try jacking the wheel off the ground & check for play by holding the wheel & push/pull it from side to side with the handbrake off.
  1. Replies: 3
    Last Post: 8th September 2012, 12:13
  2. noise
    By leighhockey in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2012, 01:31
  3. Wheel Alignent or New Tyres? Noise Noise Noise
    By lostdog in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 13:29
  4. noise
    By reeseandellie in forum Suspension, Wheels & Brakes
    Last Post: 2nd January 2010, 22:37
  5. 1 noise solved (front Bearing) + 1 new noise (squeaking front brakes!!!)
    By joseantoniovalle in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2006, 08:54
