Results 1 to 10 of 15
Thread: Headlight Alignment help needed?
    Regular Member sparky71a's Avatar
    Apr 2006
    At the Garage
    Default Headlight Alignment help needed?
    Fitted GT150'S today and some ice white sides,had to remove motor to get to the side bulbs....
    Is there anychance that i've knocked the aligment out?
    Only tonight i've found the panoramic light of the 150's amazing,but seems a little high of the ground,certainly not giving a really noticeable foot print right in front of the car like standards,but instead going for greater distance.
    For instance the overhead signs on the A19 today were lit up amazingly,where as the footprint right in front of the motor seemed more subtle.
    Is this just the character of the lights?
    Any owneres of GT150's out there i need your help!!!
    Apr 2006
    At the Garage
    anyone with any ideas at all?
    Feb 2006
    Dorset
    Take it to a garage and have the alignment checked
    Apr 2006
    At the Garage
    Ok well if thats the only solution....
    Thought there may have been something i could have looked for at home.
    Just would have been nice to hear the opinions of other peeps with aftermarket bulbs.
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Mine make a normal beam,try taking the adjusters out and refitting just in case something moved about.
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    make sure ure motor thing is sitting in the clip properly, i removed my motor the other day and found th elight pointing upwards. i had a look behind one of the black cover/caps and saw the motor stalk thingy wasnt in its clip properly and thus was pushin the light upwards. its abit fiddly puttin back in, but managed to do it by sliding it in from the top, i couldnt push it in to the clip.
    Oct 2006
    Lancashire
    sparky - got any pictures of them in and on, ive just put in piaa spark blues, but the light output seems less than the oems though you do get a nice HID blue look from them. looking at changing the sidelights next they look so ****!!
    Regular Member RSV_Ecosse's Avatar
    Falkirk, Scotland
    GT150's fitted:-
    Sidelights are PIAA Platinum Whites.
    Oct 2006
    Lancashire
    Nice RSV - what do you think of the light output of the above GT150s to the Piaa ones you had in (and Ive now got in)? - think ill either go for those PIaa sidelights or try the LED approach which prob wont work anyway!
    Oct 2006
    Lancashire
    sparky or rsv any pics of the foot print in front of the car with them in?
  1. Headlight Alignment
    By 12345 in forum Electrical & ICE (including SatNav)
    Last Post: 24th January 2012, 20:11
  2. Headlight Alignment
    By maurauth in forum Electrical & ICE (including SatNav)
    Last Post: 21st October 2009, 17:16
  3. WARNING - Headlight Alignment!
    By parapaul in forum Vectra C / Signum Car Chat
    Last Post: 19th July 2008, 18:28
  4. headlight alignment
    By shy_stag in forum Vectra C / Signum Car Chat
    Last Post: 9th October 2007, 17:14
  5. Headlight alignment
    By The Gas Man in forum Electrical & ICE (including SatNav)
    Last Post: 12th April 2006, 18:50
vectra c headlight alignment
