Results 1 to 10 of 11
Thread: clock symbol
    Nov 2011
    somerset
    Vehicle : sri
    Engine : v6 cdti
    Default clock symbol
    hi all i have a clock symbol that comes and goes next to the clock
    what does this mean/or have i got a problem
    thanks gibby
    This is the RDS reception symbol for the clock and calendar, to confirm it is receiving from the local radio transmitter
    Mileage : 000
    You will find this symbol will be associated with the correct time too.
    Nov 2011
    somerset
    Vehicle : sri
    Engine : v6 cdti
    my clock lost 7 hour early this week any reason for this
    Mileage : 000
    Quote Originally Posted by g18bus View Post
    Does your car have the symbol next to the "hands of the clock", and do you still have the VX radio" installed (not aftermarket)
    Check the stored time and date
    If the signal is lost then it may return to the stored time
    Equally, the RDS signal may be incorrect
    I had to report Radio Clyde as they provide the RDS signal in the central Scotland area
    From 01 January 2000 the date and time was wrong and it took them three months to correct the error
    I had to set the radio to NOT receive the RDS signal and set the date and time manually
    You may want to try this and compare
    Mileage : 000
    Or set to a BBC station that has RDS.
    Nov 2011
    somerset
    Vehicle : sri
    Engine : v6 cdti
    i still have the vx radio
    not sure if the rds is alway on
    Regular Member DurhamRed's Avatar
    Co. Durham
    Vehicle : Vectra SRi
    Engine : 1.8VVTi
    RDS will be on if your radio display shows the station name and not the frequency. For example "Radio 1" not "98.1 FM". Also some local radio signals aren't strong enough as you travel around the district to allow the clock time to align itself with the RDS therefore occasionally the clock symbol wont show. AS A GENERAL RULE OF THUMB - the best channels for RDS time signals are the BBC channels so periodically tune to Radio 1 for 10 mins or so and pick up the accurate clock time from that.
    Quote Originally Posted by ed taylor View Post
    Wasn't aware you could do that, as each region only has one station that provides the CT signal for RDS
    In the west of Scotland this is Radio Clyde (I had a map for the rest of the UK, but cannot find it at the moment)
    So even if you are listening to any other radio station, CD, or even if the unit is off, the clock still receives the signal only from the radio station transmitting the CT signal
  1. spanner symbol
    By tecg in forum Engine & Drivetrain
    Last Post: 27th May 2012, 19:39
  2. Camera symbol in car????
    By dannyjpuk in forum General Motoring Chat
    Last Post: 15th December 2011, 11:12
  3. Symbol
    By capria in forum Vectra C / Signum Troubleshooting
    Last Post: 4th July 2011, 21:03
  4. Anyone know what this warning symbol is???
    By n_hudson in forum Vectra C / Signum Troubleshooting
    Last Post: 7th July 2010, 10:46
  5. + symbol
    By paulhb in forum General Chat
    Last Post: 2nd July 2009, 12:05
