Results 1 to 10 of 15
Thread: Front brakes seizing
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    Default Front brakes seizing
    Hi driving my 2.0dti 52 plate veccy today and i noticed she wasnt pulling like normal.i put my foot down and the brakes locked on and smoke was pluming from the front brakes.they were red hot and stunk of burning pads.it has cooled down now but drivibg it slow they are still resisting to free when i take up drive?!can anyone help me as i dont have a clue whats happened!?thanks
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    Can anyone help?please.
    wirral
    36 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    How many miles has car done?
    Is it both front brakes seized on?
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    Its done 95,000 miles nowt for age.yes its both brakes seized on and stinks of burning brake pads and discs look blueisH.any ideas then mate?
    Equally, has there been any noted brake performance issues, or was this sudden?
    By putting your foot down, I assume you mean a normal service brake application, and not the gas
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    Yes it was on the gas!it had rear brake pads done about a month ago but its never had any brake issues ever?
    wirral
    36 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    As above is this first sign of brake problems. When was fluid last changed?
    When where pads last changed?
    Is the car used daily or has it been sat for a while?
    Definatly got friction material left?
    As weird for both to seize at same time.
    My thinking is pads worn down. Metal to metal contact is starting to weld pads to disc? :-/
    Or abs pump playing. Although am sure their plumbed opposite corners is front right and rear left.
    Think really unless you can do it. Get a garage to strip an clean the brakes.
    Maybe just by coincidence the both front pistons are stuck.
    weird usually rear calipers that are seized
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    Pads are about a year old same as fluid as vauxhall changed it same time as pads .i drove the car a small distance and there is resistance sumwhere.its baffled me true this has.There is no metal on metal contact anywhere.
    Jun 2011
    west mids
    could be collapsed brake hose
    wirral
    36 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Can you jack it up and check that both fronts are seized?
    Defiantly a weird one mate.
  1. Replies: 14
    Last Post: 3rd September 2011, 20:23
  2. Front brakes
    By mann3210 in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2011, 16:05
  3. front brakes
    By surreyl31 in forum Suspension, Wheels & Brakes
    Last Post: 26th February 2007, 06:52
  4. 1 noise solved (front Bearing) + 1 new noise (squeaking front brakes!!!)
    By joseantoniovalle in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2006, 08:54
