Thread: Some info for headlight washers
    gwent
    confused Some info for headlight washers
    Hello just a quick one for some info about headlights washers I got fitted on a 07 facelift when you wash the screen do the headlights wash as well or is there a set wash system as after 4 washes of the screen then the headlight washers work and does the headlights got to be on. Why i'm asking is I only seen them work once and that is when I fitted them
    They should operate with the headlamps in the dipped on position and the wipers in the full on position
    What you might want to do is have someone in the drivers seat, ask them to apply water to the windscreen after 10 sweeps of the wipers (to prevent windscreen damage)
    You then stand at the front of the vehicle and can observe
    gwent
    Thanks for the info
    Glasgow
    Quote Originally Posted by wayne10244 View Post
    The headlight washers will work when your headlights are turned on and you activate your windscreen wash, simples. Although there is a small interval of 2 minutes i believe where they wont reactivate to save wasting your screenwash. To add to this if they try to activate them in extreme cold where the bumper insert are frozen this pops the fuse as a safety cut out as not to cause any damage to the pump etc.
    Wipers in the full on posititon?? Apply water to the windscreen??? Why?
    Does your vectra have headlight washers or am i just confused by your post?
    gwent
    Yes my car has headlight washers but I only seen them work once !
    Glasgow
    I would check the fuse in the fuse box in the engine bay. I cant remember what fuse it is off the top of my head but its listed in the owners manual.
    As mentioned - headlights on, windscreen washers on and every two minutes or so headlight washers will work too. Simples.
    Quote Originally Posted by byebyeitsagsi View Post
    Refer to OP, wants to check how the headlight washer work, and that they are indeed working
    But the wipers have no connection to the headlight washers.....
    Quote Originally Posted by Penfold101 View Post
    They should do, as leaving the lights on and headlight washers will only operate once
    Switch the wipers on, then operate the windscreen washers (to prevent damage to the windscreen), and compare
    After about the fourth operation of the windscreen washers the headlight washers should also operate briefly
    It's similar to the rear wiper which is intergrated to the reverse switch circuit, there is no bypass for that either
  1. Headlight washers
    By signum_rob in forum Vectra C / Signum Car Chat
    Last Post: 3rd September 2011, 08:25
  2. headlight washers??
    By vauxhall-john in forum Bodywork & Interior
    Last Post: 4th January 2011, 13:21
  3. Headlight washers
    By rockh in forum Styling
    Last Post: 30th July 2009, 22:14
