Thread: Blown Exaust
    Regular Member rockafella8587's Avatar
    Nov 2011
    Akrotiri, Cyprus
    Default Blown Exaust
    Guys,
    Would a blow in the flexible joint near the front of my exhaust cause a loss of power in my CDTi 150? No power after 2700rpm, turbo kicks in then fades away. Leak test done, no boost leaks!
    South Central England
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Unlikely, sounds more like the ECU limiting fueling. Are there any fault lights on?
    Quote Originally Posted by rockafella8587 View Post
    Guys, Would a blow in the flexible joint near the front of my exhaust cause a loss of power in my CDTi 150?
    If the exhaust is faulty then you should be able to hear this, especially between 10 and 25mph
    It can affect performance, but it wouldn't normally limit revs, so as above the EMS appears to be applying safe mode
    Nov 2011
    Akrotiri, Cyprus
    I can hear exhaust gasses escaping from the blow in the exhaust but there are no warning lights on. I will see how it is after the exhaust gets fixed. The car still pulls up the rev range but it's definitely not got the power it should have. Might have to get a proper look at it and check all the turbo/intercooler hoses and be sure there are no other leaks. Not sure what kind of leak test the garage did when it was in. What a pain, ive only had the car a month! It's only done 65k so hope it's nothing major!
  1. Signum exaust knocking...
    By signum_rob in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2010, 20:33
  2. Twin exaust conversion
    By ncfcsignum in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2010, 15:01
  3. Duel exit exaust
    By paul_sri150 in forum Diesel Engine related
    Last Post: 23rd June 2010, 20:37
  4. 2.2 dti vec double exaust wants
    By m8wos in forum Styling
    Last Post: 20th June 2008, 21:05
