Thread: Fuel filter fitting/locking
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    5 Post(s)
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    Default Fuel filter fitting/locking
    When fitting a new fuel filter on a cdti should the filter lock into position?
    When i changed mine a few weeks ago i aligned it up and the rotated it but it just kept dropping off with the smallest of pressure.I tried every possable way to get it to lock but it wouldnt.After reading the "how2" again the OP said it should lock into place after you align the arrows and rotate it.
    Im 99% sure that the filter inside is just laying at the bottom of the cannister as when i had to re-tighten(hammer and screwdriver) i could here it knocking about on the inside.
    Now im suffering with a definate difference in power through all the gears and the car feels a bit sluggish
    Could the reason for this be the fuel filter sitting in the bottom of the cannister?
    Its totaly my fault as it was a very cheap filter from ebay and a make i hadnt even heard of
    Vehicle : Jaguar XF 2.2 Sport LE
    Trim : leather
    Engine : 2.2 d
    The filter on the cdti twists and locks into place on the filter lid, it is normally made from a white cotton like material and not the pleated paper yellow coloured filters that you usually see on sale for the older dti models.
    Edit: The last time I checked the part No for the filter fom Halfords was HFF282 for the 1.9 cdti models.
    I hava a feeling that you have bought a filter for the DTI models as when I went to ebay for a service kit for the cdti every thing was correct except the fuel filter which was the pleated paper type and was the one for the dti models
    Aug 2011
    Basingstoke
    5 Post(s)
    Trim : SRI
    thanks for the reply mate.
    the filter is the white cotton one and the part number listed on the item description was the same as the VX part number but the quality wasnt as good as the one i took out.Heres a link to the one i brought.
    http://www.ebay.co.uk/itm/2708430810...84.m1439.l2649
    Do the symptom my car is suffering sound like it could be the filter not sitting where it should in the housing?
    Ive just orderd another one from euro car parts as they are doing 25% off ATM so i got 1 for £16 which im collecting 2mor
    Trim : leather
    Engine : 2.2 d
    Hi justin, ive just looked through the invoices I have and the Vauxhall part No on the ebay add is the same as the fuel filter part No on the main dealer invoice I have but the filter if it is the correct part should have been a twist fit on to the filter lid. I cant say if the filter not sitting properly in the housing will be the cause of your problem though, sorry.
  1. Replies: 19
    Last Post: 30th May 2012, 15:53
  2. Locking Fuel flap
    By tubby in forum Vectra C / Signum Car Chat
    Last Post: 21st May 2012, 21:19
  3. How do i remove the fuel lines from 3.2 fuel filter...?
    By killer_bunny in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2010, 23:07
  4. Anyone added a locking fuel filler cap?
    By vxvirgin in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2008, 19:29
  5. Oil Filter location and Fuel Filter
    By trickydickySRI in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2006, 10:31
