Thread: I have all these fault codes??? 1.8vvt
    Regular Member Niall83's Avatar
    Nov 2009
    Belfast
    Default I have all these fault codes??? 1.8vvt
    Well after replacing a fuse at the passenger door to fix why my interior lights wern't working. It was a10amp fuse, I took a 10amp fuse from the engine compartment F14 which said was for headlight washers which I don't have (yet). I went for a drive and the car felt slow and no real power, on the return trip the engine light came on. So I checked the fault codes and this is what I got.
    Total number of fault codes: 7
    - PC based diagnostic tool
    P0100 - Mass Or Volume Air Flow Circuit Low Input (06) - Present
    P0130 - O2 Sensor Circuit Open (Bank 1 Sensor 1) (04) - Not present
    P0135 - O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 1) (02) - Present
    P0141 - O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 2) (02) - Present
    P0597 - Coolant Thermostat Valve Circuit Low Voltage (02) - Present
    P0075 - Intake Manifold Solenoid Valve 1 Circuit Low Voltage (06) - Present
    P0010 - Intake Camshaft Phasing Powerstage Circuit Low Voltage (02) - Present
    Would removing the F14 fuse cause this?? I have't tried swtiching it back as its dark now and **** outside but will tomorrow.
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    there could well be a few other circuits than run off that fuse other than the headlamp washers.. when you get a new fuse, clear your faults and see what happens then, which i expect is what you will be doing anyway..
    Nov 2009
    Belfast
    Yeah gona get a fuse tomorrow and try it. Has to be it, as all them things can't just go like that. But I know thw thermostat is faulty just don't have the money to get it yet.
    Nov 2009
    Belfast
    Replaced fuse and all good again.
  1. fix fault codes
    By tony923152d in forum Electrical & ICE (including SatNav)
    Last Post: 1st June 2012, 13:38
  2. 2008 1.8vvt ignition/injector fault
    By bri_m in forum Engine & Drivetrain
    Last Post: 22nd June 2011, 10:31
  3. fault codes
    By Big Knox in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2011, 10:20
  4. help with fault codes
    By vectragsi3.2 in forum Engine & Drivetrain
    Last Post: 28th January 2011, 19:11
  5. Fault Codes
    By MURDO in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2011, 09:32
vectra c p0075
vectra c fault codes 1.8vvt
vauxhall vectra c 1.8vvt 0141 error
