Results 1 to 10 of 14
Thread: Oil Change - 1.8 VVT
    Barrow In Furness, Cumbria
    Default Oil Change - 1.8 VVT
    Is there anything I should watch out for when changing the oil on a 2008 1.8 SRi?
    Is the drain plug a normal socket?
    Thanks.
    East Midlands - Regional Organiser new boy's Avatar
    Nov 2010
    lincs
    64 Post(s)
    Vehicle : Design
    Trim : SRI LEATHER
    Engine : 1.9 cdti
    Year : 56
    No m8 drain plug is a 30 or 40 torx bit cant remember of the top of my head. dead easy thw.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Apart from hoping the garage haven't over tighten the sump plug
    Regular Member Fireyfella's Avatar
    Jun 2007
    York
    Vehicle : Vectra SRi NAV XP2
    Engine : 1.9 CDTi
    Mileage : Plenty
    make sure you have plenty of old news papers on the floor, just did mine and what a mess i left on the drive as the oil tracked everywhere when i replaced the filter....
    Sep 2009
    Audley STAFFS
    make sure you give the hole where the torx bit goes ( I Thought mine was a T45) A realy good clean out, give it a squirt of WD or somthing similar, the torx bit goes in quite a long way if the hole is clean clean, the sump plug torx hole is very easy to damage if the bit is not fitted correctly, a front fitting spin off for for the oil filter is handy as there is not a lot of room to get a side fitting one on.
    Full Member
    Dec 2010
    London
    Engine : Z18XER
    Oil filter should be 30mm socket iirc
    Dec 2011
    Woking
    Trim : Exclusive
    Engine : 1.8vvt (Z18XER)
    Mileage : 58000
    I have to do this job soon - looks like the filter is the paper type which fits inside a canister. Is this right ? I thought these went out years ago !
    (Just got the vectra)
    Dal
    Nov 2010
    lincs
    64 Post(s)
    Vehicle : Design
    Trim : SRI LEATHER
    Engine : 1.9 cdti
    Year : 56
    Quote Originally Posted by Dal5band View Post
    Dal
    yes m8.
    Jun 2007
    York
    Engine : 1.9 CDTi
    Mileage : Plenty
    Dal
    Yep, just at the front right next to your exhaust manifold. simple job but as i said before a bit messy if you dont sheet up
    This is for a 1.8 VVTi though, not sure about others
    Cheers for the replies.
  1. Automatic Gearbox Oil - Change Or Not Change?
    By rocket999 in forum Engine & Drivetrain
    Last Post: 24th May 2013, 17:50
  2. Manifold change poll: Actuator change or not
    By hertscol in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2012, 18:52
  3. Oil Change
    Last Post: 22nd March 2012, 10:45
  4. Change Discs - Change pads?!?!
    By Leemarksmith in forum Suspension, Wheels & Brakes
    Last Post: 11th April 2010, 09:54
vectra c 1.8 vvt oil
vectra c 1.8 oil type
oil.for vectrac vvt
how do I replace oil filter vectra c paper type
vectra 1.8 vvt oil type
whats the best oil for vectra 1.8 vvt
vectra c oil change
vauxhall vectra 1.8vvt oil
what oil is best for 1.8vvt vectra
vectra c 1.8 vvt engine oil
vectra c 18 vvt oil
vetra c 1.8vvt oil
vectra 1.8 vvt oil capacity
which oil vauxhall 1.8 vvt
vauxhall vectra 1.8 vvt oil
oil for vectra c 1.8 vvti
best oil for vauxhall vectra 1.8vvt
vectra 1.8 vvt oil
what engine oil does vectra c 1.8 vvt sri use
vectra c 1.8 oil capacity
vectra 1.8 vvt high milage oil
what oil for vectra c facelift 1.8 vvt
vectra c 1.8vvt engine oil capacity
