Results 1 to 10 of 11
Thread: rear discs and pads
    Aug 2010
    york
    Default rear discs and pads
    Hi need new rear discs and pads for my vectra c 2003 dti,can anyone tell me which ones to go for
    11 Post(s)
    Quote Originally Posted by tomo610 View Post
    As in size or make?
    Size - http://www.vectra-c.com/forum/showthread.php?t=139088
    Make - Ones supplied over the counter at your local Vauxhall dealer, or slightly cheaper from www.autovaux.co.uk which supply the same OEM parts.
    Aug 2010
    york
    Thanks for info,
    Aug 2010
    york
    Hi just replaced rear discs and pads,followed how 2.
    foot pedal soft pumped it several times slowly till hard then when you go back to it its soft again.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Bleed brakes
    Double check all unions and pipes at rear, getting air in somewhere
    Aug 2010
    york
    will check that in morning,i have noticed the handbrake is alot higher now when pulled,would that have anthing to do with pedal being soft.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Did you pump the pedal before pulling handbrake?
    Aug 2010
    york
    yes pumped pedal slowly then applied handbrake.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    It'll take few days for Hand brake travel to sort it's self out.
    Aug 2010
    york
    the soft pedal is puzzling me,will get it looked at 2moro never had this problem before.
  1. Rear discs and pads!?!?!?
    By Basher1 in forum Vectra C / Signum Car Chat
    Last Post: 8th October 2012, 17:36
  2. How much am I looking at for new rear discs and pads??
    By Vaux-Man-G in forum Suspension, Wheels & Brakes
    Last Post: 4th December 2011, 16:20
  3. how much for rear discs and pads??
    By delberto in forum Suspension, Wheels & Brakes
    Last Post: 16th February 2011, 12:08
  4. Mintex Front Pads, Rear Pads and Rear Discs
    By The Gas Man in forum Parts for sale
    Last Post: 6th January 2008, 00:34
