Thread: Reverse gear - weak spring on gear stick
    Dec 2011
    Woking
    Trim : Exclusive
    Engine : 1.8vvt (Z18XER)
    Mileage : 58000
    Default Reverse gear - weak spring on gear stick
    I seem to have a weak spring which pushes down the reverse selection ring. It dosn't have nice springy action, is it possible to replace this spring ? Pehaps someone could describe where this spring is ?
    I have read the horror stories about removing the gear knob with a hacksaw - don't fancy that !!
    (Vectra Exclusive 2007 1.8 VVT)
    Regular Member shane31's Avatar
    Sep 2011
    Staffordshire
    Just pull the knob really hard buddy it will come off but watch for the spring as some times it can go flying... Maybe then just re stretch it a bit? It may work if not im sure some one else will have an idea..
    Dec 2011
    Woking
    Trim : Exclusive
    Mileage : 58000
    I'm beginning to think some B*** has already re-stuck this gear knob in the past and left the spring out ! I'll try a few things .......
    Dec 2011
    Woking
    Trim : Exclusive
    Mileage : 58000
    Temporary fix for reverse lift ring spring: elastic band pulling down under the gaiter - works fine. I kept the tension quite low so there is no interference with the gear change.
    Dec 2011
    Woking
    Trim : Exclusive
    Mileage : 58000
    error please delete
    Last edited by Dal5band; 20th December 2011 at 13:21. Reason: error - please delete
    Regular Member Fireyfella's Avatar
    Jun 2007
    York
    Vehicle : Vectra SRi NAV XP2
    Engine : 1.9 CDTi
    Mileage : Plenty
    You will struggle to get just a VX Spring as they would not sell me it as a part and most breakers want to sell you the whole gear stick and linkage as well.
    When I got my car the spring was missing as the gear knob in infamous for coming off but as you say yours may have been stuck back on. If you go to a scrappy that you can take parts off yourself you should be able to get on off any Vectra C as they are all the same.
    I did that and mine is fine now, you could try using an open ended spanner under the knob and hitting the spanner with a hammer to ‘help’ it come off?
    Hope that helps a little?
  1. Engaging reverse gear
    By julian924s in forum Engine & Drivetrain
    Last Post: 30th January 2011, 18:31
  2. Vec C 52 plate 2.2 Dti Gear Stick Jumps out of 1st gear on take off
    By ukwanderer01 in forum Engine & Drivetrain
    Last Post: 5th July 2009, 21:43
  3. Reverse gear
    By Dave1.8 in forum Vectra C / Signum Car Chat
    Last Post: 3rd October 2007, 15:47
  4. Reverse to 1st gear
    By MalcGSI in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2006, 04:07
vauxhall vectra gear knob spring
2006 vectra gear lever replacement
gear stick reverse spring vauxhall vectra
corsa c gear knob not springing back
vectra reverse gear color spring
vauxhall sticking reverse lift
Vauxhall 9zafira reverse gear interlock stuck up under gear knob
how to repair spring in a vauxhall signum gear stick 06 plate
vectra c reverse selector fix
vectra c wont go in reverse
Opel twinport no reverse how to get gear lever off
vectra c stuck in gear
vectra c reverse lever on gearstick broke
vectra 2007 reverse gear lever
vauxhall vectra c reverse gears
2005 vauxhall vectra 1.9 cdti not going in reverse gear
vauxhall corsa d stuck in reverse
vauxhall vectra gear stick
gear lever spring corsa c
gear spring for vauxhall vectra
where does the spring go ona vecrea gear knob
