Thread: rear wheel bearing
    Aug 2011
    Norfolk
    Default rear wheel bearing
    How hard is it to replace a wheel bearing and is this something an amateur mechanic can fix or should I take it to a garage?
    Bearings cost around £45-50 off ebay, how long does it take to fit?
    Appreciate your help!
    Regular Member Chuff's Avatar
    Sep 2011
    Oxfordshire for Pleasure, Berkshire for business
    definately the rear wheel bearing
    i thought one of mine had gone but alas wasnt the case
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    are you changing it because you can hear it humming? if yes swap tyres around and see if it goes? might be just a tyre getting near the limits
    As above, what is the diagnosis that makes you suspect or know it is the rear bearing, or are you just simply interested in the procedure for changing?
    Presumably it is a MoT fail point or advisory on service?
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Did both of my rears about 4 weeks ago on the drive - trolley jack and axle stands. I bought these ones http://www.ebay.co.uk/itm/3006069711...84.m1439.l2649 but the same seller IIRC also does them individually.
    The first one took me two hours, the second one about an hour. Just depends if all the bolts come out easily .
    Sep 2011
    Sipson
    I had mine done last week, you can get cheap ones off Ebay, but once I was 100% sure it was the bearings and not the tyres I just wanted it done, so was prepared to pay, so was £180 fitted, is nice driving now and only hearing the thrum of the tyres, and not the borked bearings and brake calipers (just prior).
    I diagnosed mine as the bearings after realizing the sound started as soon as the car moved, and also the sound was constant on all road surfaces. And it was poked, I had a play with it afterwards and was shocked I had been doing 100mph on that thing, lucky it didn't disintegrate.
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    you will be ok billy it's a straight forward job ,just make sure you have a universal joint for your socket set.
    Aug 2011
    Norfolk
    tyres are about 18 months old, the humming from the near side rear is fairly loud especially when going round corners, some days louder than others.
    I really need a nice vectra c chap to help with cam belt, wheel bearings and front knocking noise, any takers?
    wirral
    42 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    I would if in was closer
    Dec 2011
    norwich
    i can help if needed.
  1. Rear wheel bearing/hub help
    By daviem-rfc in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2010, 23:38
  2. rear wheel bearing??
    By SRimonkey in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2010, 22:14
  3. Rear Caliper \ wheel bearing
    By dmcl in forum Suspension, Wheels & Brakes
    Last Post: 17th July 2007, 22:23
  4. Rear wheel bearing
    By barney in forum Vectra C / Signum Car Chat
    Last Post: 13th April 2006, 16:23
