Thread: Bulb failure light on dash - always on.
    Dec 2011
    Woking
    Trim : Exclusive
    Engine : 1.8vvt (Z18XER)
    Mileage : 58000
    Default Bulb failure light on dash - always on.
    My bulb failure light is always on - in the middle at the top of the dash display. It is showing white - is this normal ?
    (Handbook says it glows red if there a bulb failure and I don't think there are any bulbs failed).
    Vectra C 2007
    Dal
    Regular Member benny's Avatar
    Feb 2006
    dudley
    you have 2 bulbs that have failed on the rear ...both top rear red lights wont be lightin up ..
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    the bulb warning doesn't change colour if its lit up you must have a bulb off check the rear because there's 2 bulbs either side for sidelights/stop lamps might be one of them off .
    Dec 2011
    Woking
    Trim : Exclusive
    Mileage : 58000
    OK - will check tomorrow.
    (Only just got the car)
    newport
    if one of the rear bulbs fail it sends power to another one on the rear so you always have 2 red lights either side
    Quote Originally Posted by taffy bhoy View Post
    Incorrect.
    There are 2 tail lights either side (both of which work at the same time), one of which also acts as the brake light. Should the upper of the 2 tails lights fail, then the lower tail light takes over the role of tail/brake light instead.
    In other words, if one of the rear tail light bulbs fail, then you are left with one, not two (per side). However you should be left with a complete set of braking lights.
    Rear light positions (from the top down)
    Indicators
    Tail & brake lights
    Tail lights (which then becomes a brake light as well should the original tail/brake light fail)
    Fog light (drivers side only - UK)
    Reverse lights.
    All bulbs are 21 watt single filament bulbs.
    Dec 2011
    Woking
    Trim : Exclusive
    Mileage : 58000
    Yep - top side/brake bulbs were blown. Normality restored on dash. I persume the lower ones last longer because being 21w they have to be under run.
    Also replaced the yellow indicator bulbs - the old ones had a coating which had shrivelled up.
    Quote Originally Posted by Dal5band View Post
    Nope, because the upper ones are also the brake lights, they're used more than the lower ones (unless you drive round with your lights on all day)
  1. Dash Board headlight bulb failure
    By srobertson1 in forum Vectra C / Signum Car Chat
    Last Post: 18th July 2012, 21:34
  2. Bulb Failure in Dash
    By TheVoid in forum Electrical & ICE (including SatNav)
    Last Post: 10th May 2011, 15:50
  3. bulb failure warning light on dash
    By bigbill94 in forum Electrical & ICE (including SatNav)
    Last Post: 9th June 2010, 19:35
  4. bulb failure light
    By paulzvectra in forum Vectra C / Signum Car Chat
    Last Post: 15th July 2009, 20:03
why does bulb fault always show in vectra
vauxhall vectra rear bulb failure
vectra c bulb failure which bulbs
