Thread: 2.2 DTI Starting Drama's
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Default 2.2 DTI Starting Drama's
    Evening all
    I'm having a couple of drama's starting my car for the last week
    First thing on a morning, if the glow-plug light comes on, it starts fine and no smoke. No Problem.
    If i pop out from work at lunchtime, starting can take a few turns followed by a small cloud of blue smoke which disappears after 1 or 2 seconds and is fine after. I've had the glow-plug light come one once this week at lunch when i popped out and it started without a problem
    The engine is fine power-wise, pulls smooth etc.
    Recent work done before this has started happening:
    New airfilter (bosch element)
    New thermostat
    EGR cleaned (thoroughly, although it wasn't that bad)
    Havn't done the oil yet due to sump plug "issues"
    Is there anything obvious i should be checking? Or is there a troubleshooting guide for starting issues i could take a look at?
    Thanks Chaps
    New Member melvyn8181's Avatar
    Jul 2011
    north lincolnshire
    possibly change plugs and fuel filter, thats what i did on my 2.0 dti and it helped a little
    Regular Member benny's Avatar
    Feb 2006
    dudley
    there is a ecu update that will fix this ....ask your local dealer ...they will charge you for this
    Sep 2011
    Sipson
    Oh really? I have similar issues too, though mine starts better in the freezing cold 1st thing, and worse at night after sitting in an underground car park all day, no glo plug warning, but it can take 5-8 turns to fire, and always with a puff of smoke.
    I might ask NOW vauxhall what the story is.
  1. Not Starting
    By mungo1985 in forum Engine & Drivetrain
    Last Post: 11th September 2012, 21:52
  2. Not starting..... Possible Starting Motor
    By portreathbeach in forum Vectra C / Signum Troubleshooting
    Last Post: 25th August 2012, 11:30
  3. bad starting
    By reg in forum Engine & Drivetrain
    Last Post: 20th April 2011, 09:01
  4. Starting on 3
    By keefy*2010 in forum Diesel Engine related
    Last Post: 15th January 2011, 03:09
  5. EML flashing when starting but not starting (Vec-B)!
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 29th July 2009, 15:51
