Thread: I am a silly prat.. literally
    Regular Member weverall's Avatar
    Littleport, Ely, Cambs
    Default I am a silly prat.. literally
    Tried to update the CD70.. but then it stalled/failed
    now all i have is BC... and the CD70 display wont turn off when i look the car etc.
    Help.
    Anyone near Cambridge able to help! !!!!
    Sent from my GT-I9000 using Tapatalk
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Hammer lol no idea mate try dissin the battery
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Put update disc in again and see if it starts, if not then pull power to radio for an hour then plug back in and retry.
    If it still won't update then only other option is to hold down audio button until boot loader screen apears then reset radio eeprom
    Irmscher Insignia CDTI 130
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Fixed. Just kept retrying. Now to drink
    Aug 2010
    Stoke on Trent
    You MUST use a genuine firmware update disc. I tried updating mine via a non-genuine disk (downloaded of the internet) and thought I'd bricked it... I ordered a genuine firmware update disk from Vauxhall and that cured it.
    Sep 2011
    Newport
    I done exactly the same thing a few weeks ago. Mine had the update disc stuck inside and would not eject after i tried tp update it with a downloaded disc. Ended up having to remove the CD70 and removing the bottom plate to access the drive and manually remove the CD.
    On the right hand side there is a screw that holds a small metal plate onto the board (Sorry havent got any images at the moment) under this is the loading motor, move the cog and this will eject the CD and lower the loading lock function (2 bits of plastic pop up infornt of the drive to stop you from loading a disc on top of one that is already in there)
    I didn't know about this until i put everything back together, with the disc out, tried to put a proper update disc in, and I didn't make sure the locking system had reset, had to pull it all apart again
    Once that was all done, inserted the firmware disc from VX only a fiver, all went through fine.
    YAY!!!
    Hope this helpes if someone like me decided to update from an Online Source (DON'T DO IT!!!!) It's not worth the hastle.
  1. Literally had my car two weeks and.. :(
    By Shogun in forum Vectra C / Signum Car Chat
    Last Post: 23rd August 2011, 12:26
  2. What a prat!
    By arkhan78 in forum The 'Off Topic' room
    Last Post: 3rd June 2009, 16:03
  3. adult words are often taken literally.....
    By Vaux-Man-G in forum Comedy & Humour
    Last Post: 13th March 2009, 22:39
  4. I feel a right prat and now £220 lighter for the privilege!
    By colalowe in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2009, 18:02
  5. Some more light relief.......literally!!!
    By Drinky in forum Comedy & Humour
    Last Post: 24th February 2006, 13:08
