Results 1 to 10 of 18
Thread: advice
    Jul 2011
    UK
    Year : 06
    Default advice
    As some of you know am getting a das6 for Xmas aswell as aload of other detailing products
    Now does this seem right
    Wash the car and clean wheels
    Rinse
    Clay the car using bilt hamber clay (while car still wet aswell as spraying water on to the body)
    Wash the car again
    Rinse
    Blade and dry
    Mask up the car with blue tape
    Using the das and a megs finish pad with megs 80 to start and 83 for more heavy swirls
    Going over the car with a couple of passes till happy and use a diffrent pad if not removeing swirls
    Now what I want to know after I have done this do I then use colly wax on the car by spounge pad to apply then microfiber to remove or do I use the das
    Regular Member disco dan's Avatar
    Apr 2011
    Southport
    Jesus marc, im tired just looking at that process!!
    Jul 2011
    UK
    Year : 06
    Going to take more than a day to do but will be worth it in the end
    Apr 2011
    Southport
    it sure will and i think im warming to the idea myself.
    Jul 2011
    UK
    Year : 06
    U should mate can imagine will look almost new when its done
    Jul 2011
    UK
    Year : 06
    Anyone
    Jul 2011
    UK
    Year : 06
    Woodbridge
    Hi mate, Rinse the car first off to remove larger debris. Try to get it as clean as possible before touching it (this is why snowfoam is so good). I personally would not use a blade to dry, try using an open ended hose to chase the water away then use a drying towel. The rest seems fine. As for applying wax I would just use a foam applicator pad and do it by hand, never seen the need or point to apply wax by machine. HTH
    Jul 2011
    UK
    Year : 06
    Thanks mate I don't like drying towels really I use autoglym chamios making sure always clean before use but yeah that helps a lot bring on Xmas day
    Slough
    91 Post(s)
    Vehicle : insignia vxr
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    Marc join up on detailing world there is a lot off reading info that will tell you all you need to know . also the traders on there give good discounts . one thing just dont buy all the stuff leave some for us khalid
    the vectra has gone , but not far away so ill still see it form time to time
  1. ebay advice , think someone is trying it on , need advice ...
    By poves in forum General Motoring Chat
    Last Post: 22nd August 2012, 00:29
  2. Need help and advice please
    By Angel1368 in forum Engine & Drivetrain
    Last Post: 9th June 2012, 11:19
  3. Need advice what would you do....
    By pipamish in forum General Motoring Chat
    Last Post: 2nd December 2011, 02:13
  4. Newbe after advice, lots of advice!
    By rb199 in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2011, 19:08
  5. Advice please?
    By RN37 VXL in forum Engine & Drivetrain
    Last Post: 16th October 2009, 17:59
