Thread: whos lowered and bothered fitting camber kit?
    Regular Member Jow20's Avatar
    Sep 2010
    Leeds
    Default whos lowered and bothered fitting camber kit?
    Im noticing since lowering 35mm the inners of my tyre wear quicker! From what i gather its the camber, but you can but an eibatch camber kit for around 20 pound that allows for this lower setting... has people bothered fitting this when lowered or will it entail alot to fit now the car is already lowered? Big job?
    Regular Member Mads's Avatar
    Ipswich,.UK
    when i lowered mine on eibachs i had a full alinement check done and they adjusted all the cambers, toes etc to suit (zero) had no probs
    Slough
    90 Post(s)
    Vehicle : insignia vxr
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    same a mads ( nathan ) i never fitted the camber kit either . khalid
    the vectra has gone , but not far away so ill still see it form time to time
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Some of the Vecs have camber adjusters already front and rear, but apparently not all. Mine did too but the guy that did it was surprised as he didnt expect it to have.
    Regular Member vxpenfold's Avatar
    Nov 2010
    sittingbourne,kent
    Vehicle : Vectra Hatchback
    Trim : Life(well it was)
    Mileage : 166000
    yh ive got stock adjustable camber and toe on the rear so just had them adjusted to suit along with the front toe and camber(coilovers have slotted top holes )
    Apr 2011
    Las Vegas
    Demon Tweeks fitted the Eibachs to my Siggy, they did the set up afterwards. Not had any issues
    spoons
    Guest
    I have KW Coilovers on the VXR but never used the camber kits in the end.
    No need to unless your tyre walls are same level or below the wheel arches
    Just get it 4 wheel aligned with camber adjustment
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    Yeh as said laser alignment and you will be fine
    Cheshire
    I had to fit front camber bolts, simply to put 1 deg neg on the front, the rear camber bolts were already on my car. The rear and thrust has to be done on a 4wheel laser rig about£70
    Regular Member big gra's Avatar
    Dec 2011
    southport
    Defo get it done, makes tyres last longer and steering feel a lot nicer as youll have more tyre in contact with the road!
  1. whos lowered their SRI
    By Angel1368 in forum Handling & Braking
    Last Post: 28th April 2012, 12:09
  2. Replies: 15
    Last Post: 4th April 2012, 13:50
  3. Fitting Lowered Eibachs
    By spatch in forum Suspension, Wheels & Brakes
    Last Post: 12th March 2010, 11:29
  4. A question that's bothered me...
    By Triple Trouble in forum General Chat
    Last Post: 25th January 2008, 21:46
