Thread: clutch starting to slip at 44K !
    Regular Member sri matt's Avatar
    Apr 2011
    dundee
    Thumbs down clutch starting to slip at 44K !
    hi guys, my facelift veccy with only 44K on the clock is starting to slip its clutch but the bitting piont is only half way up ? is this normal , p.s i dont abuse the clutch but only had the car a year ,,,there is also violent judder from it when pulling away when cold but not when hot, any help would be great cheers matt
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Not 100% but I thought this engine had a problem where the clutch throw-out bearing could fail and cause poor pressure on the clutch in that it would not engage fully. The symptoms usually were a noise (this lead to some 1.8 owners thinking they had a DMF - which they don't). Either way m8 the gearbox will have to come off.
    Like I say I'm not 100% on that.
    Regular Member DurhamRed's Avatar
    Co. Durham
    Vehicle : Vectra SRi
    Engine : 1.8VVTi
    Cold clutch judder from the 1.8VVTi is common. A replacement (improved) clutch kit from VX is the answer. My old 06 plate was ****** murder from cold and not much fun in stop / start traffic until warmed up then the judder disappeared. Judder was only a problem when pulling away from standstill in first.
    Full Member Big Sig's Avatar
    Just because you don't abuse the clutch, doesn't mean the last owner didn't drive it like he stole it!
    Full Member tolly's Avatar
    East Midlands
    Trim : SRI
    Engine : 2.2
    Year : 2002
    just had my clutch done.. 2.2 sri cost me £450 for new clutch.. luckily the flywheel was ok
    Apr 2011
    dundee
    so new clutch then, would you recomend changing the hydralic release bearing to ?
  1. New style MOT slip
    By Derek Mc in forum General Chat
    Last Post: 17th September 2012, 12:57
  2. clutch slip?
    By Mike1.9CDTI in forum Vectra C / Signum Car Chat
    Last Post: 5th May 2012, 19:47
  3. is this clutch slip?? and chucking away
    By jhalberda in forum Vectra C / Signum Car Chat
    Last Post: 18th March 2011, 13:08
  4. can clutch slip fix itself...?
    By olid2002 in forum Engine & Drivetrain
    Last Post: 19th January 2011, 20:58
  5. Clutch slip
    Last Post: 17th May 2010, 20:49
