Results 1 to 10 of 11
Thread: auto lights and wipers not working
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    Default auto lights and wipers not working
    hi all just wondered if anyone would know why my auto lights and wipers dont work properly? when i switch the lights to auto they are just permanently on and the auto wipers just dont work at all :drowning:! the only other thing is that the drivers side vanity light also doesnt work could they be related?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Could sound like a BCM related error..
    Engine : 1.9 CDTi
    Check the loom is plugged in ok at the REC as they all come from there.
    Have you had any work done on the car like a windscreen replacement etc?
    Feb 2007
    well now you mention it they have never worked since ive had it but have noticed that the windscreen has been changed
    Engine : 1.9 CDTi
    Sounds like the roof loom is damaged/ripped as incompetent window fitters 'forget' to unplug the loom from the sensor before they take the screens out.
    I would be checking that first. Might even be as simple as it being unplugged.
    Antwerp, Belgium
    i had the same problem
    when changing the window the guys from the shop had cut the wires while removing the glass.
    this made the fuse pop. With a fuse burned the lights are always on.
    Feb 2007
    where do i find the fuse? might be worth a try
    Oct 2011
    Essex
    No auto wipers? BONUS!
    Feb 2011
    Selby
    Take off the covers round the rear view mirror and see if the rain sensor is plugged in (the lights use the same sensor). As others have said - either the windscreen fitted forgot to plug it back in, or damaged it taking the old screen out.
    Feb 2007
    does the dimming mirror work on the same loom as that works perfect??
  1. The start of my mod to auto wipers and lights
    By jon1.9cdti in forum Styling
    Last Post: 8th May 2012, 12:29
  2. Auto wipers/rain sensor not working
    By Jonsey in forum Electrical & ICE (including SatNav)
    Last Post: 11th April 2012, 22:11
  3. Auto lights/wipers and 'frost'
    Last Post: 20th January 2012, 11:55
  4. Possible to fit auto lights/wipers
    Last Post: 13th October 2011, 19:10
  5. Auto wipers - working but...
    By cheekylemon in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2008, 23:12
