Thread: aerial
    Regular Member fiend61's Avatar
    Nov 2011
    york
    Vehicle : vectra 2.8 turbo
    Trim : elite
    Engine : 2.8 turbo
    Default aerial
    hi all
    can someone tell me if the radio (ncdc2013) aerial is the rear screen or the roof aerial, if it is not the roof aerial is that just for satnav?
    tia
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    I believe all models roof whip aerial is for their radio fit ..... those with satnav have the satnav antenna in the aerial base.... hence the different bases you'll see on different models.
    Nov 2011
    york
    Trim : elite
    Engine : 2.8 turbo
    cheers for that, i have satnav and the ncdc 2013 so the roof whip aerial is for both? also is the booster in the aerial base aswell, i have a problem that when i switch on heated rear screen i lose radio reception, i have heard that water ingress can cause this ?
    tia
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Very good chance the insulation has broken down in the aerial base then - as you say, water ingress is the most likely cause.
    Sadly, the best replacement option will probably end up being a brand new base as I'm pretty sure the parts are not supplied individually.
    Just to clarify.... the whip is for your radio reception.... the santav antenna is in the large aerial base the whip screws in to.
    Nov 2011
    york
    Trim : elite
    Engine : 2.8 turbo
    it all becomes clear :-)
    thanks
  1. vec c aerial
    By fiend61 in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2012, 21:33
  2. aerial
    By matreya in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2012, 15:42
  3. How much is a new aerial?
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2010, 15:00
  4. tv aerial
    By VEC-MAN in forum General Chat
    Last Post: 28th February 2010, 12:41
