Results 1 to 10 of 15
Thread: 2.2 dti starting ok but wont take the throttle straight away
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    Default 2.2 dti starting ok but wont take the throttle straight away
    it has just started this it will start ok but when i go to rev it nothing , it nearly chokes its self any ideas where to start
    i cleaned the boost sensor and took a quick look at the egr valve dasent look to bad
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    The amount of Dti starting problems seems to be growing.
    My 1st guesses are dodgy diesel (add some 2 stroke oil to diesel tank might help, and has the Diesel filter been changed?).
    Glow Plugs or Glow Plug relay packed up.
    It can also be the leak off pipes perished (check for leaks or smell of diesel at front of engine), or the one-way valve in the fuel line faulty allowing the diesel to drain back into the tank (park facing downhill, if possible, and see if it helps).
    Aug 2007
    Vehicle : ELITE
    Trim : FULL LEATHER
    Mileage : 87,000
    i might try a fuel filter all the rest have been changed lately and its deffenatley not the diesel , maybe a bbit of water in the filter head . its while smokey when it starts and a bit spluttery
    where is the 1 way valve on the fule line ? do you have a pic
    Wirral, UK
    Vehicle : Mokka
    Engine : 1.7CDTi
    I have not messed about with the one way valve, so I have no information or pic's of it.
    I only mentioned fuel quality in case you are buying fuel that has the red taken out of it, and no, i dont mean you are doing it on purpose, but you never know with small fuel stations.
    Have a look here for more info:
    http://www.uniteddiesel.co.uk/diesel-engine-smoke.php
    Aug 2007
    Vehicle : ELITE
    Trim : FULL LEATHER
    Mileage : 87,000
    thanks for the info Tony thats a good chart the low engine compresion seem to tick my boxes
    i know what you mean about the fuel but i only use good quality stuff same place as 4 years , i was caught out 10 years ago with cheap fuel so once bitten
    Wirral, UK
    Vehicle : Mokka
    Engine : 1.7CDTi
    Glow Plugs also ticks the same boxes.
    Can you use a Multimeter?
    If you can they are easy to check.
    If you have a 12V bulb on 2 bits of wire they can be checked that way too.
    Aug 2007
    Vehicle : ELITE
    Trim : FULL LEATHER
    Mileage : 87,000
    How do i check it with a meter
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    Quote Originally Posted by peadar View Post
    If its starting ok then it won't be glow plugs, leak off pipes fuel filter etc etc. I sounds to me your TPS could be faulty on the Inlet manifold
    Wirral, UK
    Vehicle : Mokka
    Engine : 1.7CDTi
    Even a cheap £5 meter will do, but £20 one's are better quality.
    Do this with the engine cold.
    Remove the caps to the 4 Glow plugs. This is fiddly.
    They are at the back of the engine and look a bit like spark plugs.
    Set the meter to the lowest Ohms range (200?)
    and short the red and black test probes together.
    Make a note of the reading, probably 0.7 or something similar.
    Now put the black meter wire on a clean earth point. A 3rd hand will be useful here.
    Now put the red probe on each of the glow plugs in turn and note the reading.
    A good glow plug should give a reading very similar to shorting the probes together, say 0.7 or 0.8, etc.
    A bad one will not give a reading at all, as it will be open circuit.
    You can also test if any voltage is getting to the glowplugs.
    Set the meter to 20Volts DC or it might have a === symbol.
    Put the black wire on the earth point, and put the red probe inside one of the glow plug caps touching the metal parts inside.
    Using your 4th hand, switch the ignition on but DO NOT start the engine.
    The meter should read about 11.5 to 12.5V until the glow plug light goes off, but it may also still read a voltage even after the glow plug light goes off.
    The glow plugs stay on after the engine has started when the temperature is low.
    Aug 2007
    Vehicle : ELITE
    Trim : FULL LEATHER
    Mileage : 87,000
    Quote Originally Posted by DTI-Steve View Post
    silly Q whats TPS ?
    Tony glow plugs tested and are dead on
    wouldnt start 1st go this morning so i took the cover off the back of the EGR valve and it was in the open so i pushed it closed and it started 1st go could this be my problem ?
  1. Steering wheel not straight, but car drives straight?
    By Danny.surname in forum Suspension, Wheels & Brakes
    Last Post: 24th February 2013, 00:21
  2. Replies: 9
    Last Post: 15th January 2013, 14:16
  3. 2.0 DTI Wont start! ( and went it does it cuts straight out)
    By Daz_m in forum Engine & Drivetrain
    Last Post: 29th December 2012, 15:11
  4. Broken car....Not atteming starting..throttle postion sensor?
    By smiley-sri in forum Electrical & ICE (including SatNav)
    Last Post: 13th March 2010, 13:28
  5. Arrrr!Throttle my Throttle Body!
    By boze in forum Engine & Drivetrain
    Last Post: 12th September 2009, 11:15
https:www.vectra-c.comforumshowthread.php152052-2-2-dti-starting-ok-but-wont-take-the-throttle-straight-awaypage2
vectra c 2.2 dti butterfly shut off valve
vectra 2.2 dti not taking throttle cutting out
