Thread: Signum TA Part Numbers
    Feb 2011
    Darlaston
    Vehicle : Vectra VXR
    Engine : 2.8 Turbo
    Default Signum TA Part Numbers
    Does anyone have the TA Wiring Bracket part numbers for the signum?
    I already have the TA and TA Base.
    I now need the TA Wiring kit for the TA Base to connect into - however there is no vauxhall dealer in the UK that has one.
    However, I may be able to get the wiring/bracket kit in separate parts.
    Essentially what I need is the part numbers for:
    The plastic 'flap' which the TA Base fits into.
    The bolts and metal plate which secure the plastic 'flap' to the transmission tunnel.
    The wiring connector and loom which bolts into the plastic 'flap' and which the TA Base plugs into.
    If anyone has the above part numbers (in grey/charcoal colour) please let me know.
    Many thanks.
    Sorry wrong Place - Admin - please move to part numbers section.
    Feb 2011
    Darlaston
    Engine : 2.8 Turbo
    Default Update
    After sending many emails i finally received an answer back.
    The part numbers I am told that together comprise the Signum TA wiring kit are:
    They are:
    931 609 52 - Wiring Harness
    131 129 58 - Bracket
    131 435 74 - Cover
    131 562 57 - Bushing x4
    131 574 03 - Screw x4
    110 944 25 - Nut x2
    110 971 41 - Screw x2
    Can anyone verify this?
    Vauxhall arn't very much help to be honest as very few of them have actually seen the wiring kit or individual parts.
    Quote Originally Posted by rajveer.sandhu View Post
    They are:
    131 435 74 - Cover
    110 944 25 - Nut x2
    i can tell you that is the correct amount of parts , not sure on the numbers but i will be really surprised if you can get it all
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    I presume you have read the how 2 and discussion. Not sure if either are any help
    http://www.vectra-c.com/forum/showthread.php?t=15099
    Feb 2011
    Darlaston
    Engine : 2.8 Turbo
    Default How 2
    Yep sure did, pictures didn't seem to load though (maybe broken links).
    Will place the order on the parts and wait and see what turns up - hopefully it will be everything I need.
    Many Thanks.
    Feb 2011
    Darlaston
    Engine : 2.8 Turbo
    Default How 2
    Many Thanks.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    All fixed now buddy
    Feb 2011
    Darlaston
    Engine : 2.8 Turbo
    Cheers.
    Now I can cross ref the parts I receive against the pics
    Engine : 1.9 CDTi
    The 'kit of parts' is now not a stocked part but you can buy the bits separate.
  1. Replies: 21
    Last Post: 4th November 2012, 22:31
  2. signum part numbers wanted please
    By deano1 in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2012, 22:21
  3. Part Numbers
    By n_hudson in forum Vectra C / Signum Car Chat
    Last Post: 23rd October 2008, 20:50
