Thread: 1.9 CDTi [150] - Thermostat Question
    North East
    Default 1.9 CDTi [150] - Thermostat Question
    Can anyone tell me if the thermostat is different on the 150 & 120 1.9 CDTi model vectra's? (talking temp thermostat)
    Getting mine changed today and want to make sure they get the right one - mine is the 150...
    Michael
    Aug 2010
    Derbyshire
    Quote Originally Posted by mpc View Post
    Michael
    Looking at listings for these they do suggest that they are the same for both engine types.
    I got mine from here http://www.ebay.co.uk/itm/Vauxhall-T...item2c61652eca and fitted to my Signum 150 last winter. Still working as it should.
    Mick
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    yes they are the same,there is a chassis break for 2007 though
    Nov 2010
    North Yorkshire
    Vehicle : Signum Elite 1.9 CDTI
    Engine : 1.9 (150)
    Mileage : 113.000
    Quote Originally Posted by MickAP View Post
    Mick
    The latest thermostat VX Pt.No.55203388, don't use an OEM version. The one under the quoted Pt No is about £45.00 from the dealer. I had what turned out to be an OEM stat fitted in June this year by a national garage and it failed in late November, they have fitted the genuine one as I asked and it is working fine. Incidental, it was cheaper for them to buy in that the OEM one had been.
    North East
    Had new thermostat fitted yesterday by a local garage (not vx) - should I be able to see any new part by just looking under the bonnet or is the thermostat well hidden away - I had a quick look but couldn't see anything that resembled a new part!
    Unfortunately the drive back to work was only a mile or two so the engine didn't get warm & needle didn't have chance to move.
    Aug 2010
    Derbyshire
    Engine cover removed, the stat is down the right side sort of under the oil filler area in this pic. That big black pipe (air charge pipe) needs to be removed to get to replace the stat. There's a black hose coming from the front of the stat which runs alongside that air charge pipe to the front and the stat's got an electrical connector to it, on top
    The temp gauge, this weather will not start to move until you've travelled around 3+ miles then should sit at around 85.
    Nov 2010
    North Yorkshire
    Engine : 1.9 (150)
    Mileage : 113.000
    What a nice clean engine - are the four yellow topped things going into the front of the engine the things that could be blue and should be upgraded to the colour ???????
    Nov 2010
    doncaster
    my 1.9 cdti 16v takes nearer 10 mile on a freezing morning to warm up
    Aug 2010
    Derbyshire
    Quote Originally Posted by alhambra View Post
    Apparently, so I've been told before, they should be changed because you will have running problems.
    No problems thus far, and I believe in the old saying "if it ain't broke why fix it" or something like that.
    Mick
  1. thermostat for z19dth , a wee question
    By simplesi in forum Engine & Drivetrain
    Last Post: 18th October 2012, 01:19
  2. Thermostat/Temperature Question
    By Kaput in forum Engine & Drivetrain
    Last Post: 2nd July 2012, 01:05
  3. another thermostat question
    By bish in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2009, 11:22
  4. Question...thermostat removall
    By Maxim007 in forum Engine & Drivetrain
    Last Post: 9th September 2009, 21:22
  5. 1.9 CDTI 120, thermostat question!!
    By bungle666 in forum Vectra C / Signum Troubleshooting
    Last Post: 9th February 2009, 00:31
