Thread: Change all bulbs but to what??
    Regular Member bigstorer's Avatar
    Swansea
    Default Change all bulbs but to what??
    As the title may suggest....
    I am looking at changing ALL the bulbs on the front end to brighter (whiter) ones.
    What would you recommend?
    Also what bulbs work well to replace reverse lights?
    Oct 2006
    North Yorkshire
    Vehicle : Astra
    Trim : GTC VXR
    Engine : 2.0 Turbo Petrol
    Year : 2015
    Mileage : 3,200
    Osram Night breakers
    Quote Originally Posted by Mark Evison View Post
    = short lived in my experience of using them. Hardly any difference (if at all) between a 2 £15 dip beam H7 NBs and 2 £4.99 Ring H7 bulbs. The ring bulbs lasted over 3 times longer too.
    As for replacing the bulbs - DO NOT use LEDs. Vectra's don't like them and you'll get bulb failure warnings and strobing effects.
    Swansea
    Thanks.
    Is there anything out there to prevent the error messages etc?
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Raise dip beam height first, as in link on terrible lights thread, if you've not already done it. Then get 50%+ or better H7's. I'm running Halfrauds Extreme a present, but intend changing to NB's next time. About the same length beam (once height adjusted from the stupidly low standard setting), but much brighter.
    Not sure if it still applies, but I always found the more yellow all weather bulbs worked better in fogs, the whiter ones didn't seem to penetrate as well.
    Vectra ones ok so not played with them.
    Swansea
    Ok thanks. I read about adjusting them before but I can't find the thread anymore.
    Has anyone got a link please?
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Quote Originally Posted by bigstorer View Post
    http://www.vectra-c.com/forum/showth...oor+headlights
  1. Change bulbs in instrument
    By zafira in forum Electrical & ICE (including SatNav)
    Last Post: 24th September 2012, 23:51
  2. Change front fog bulbs
    By KevinG in forum Electrical & ICE (including SatNav)
    Last Post: 4th December 2011, 15:02
  3. H.I.D's Fitted!!! :) Now how to change the sidelight bulbs?
    By Deann in forum Electrical & ICE (including SatNav)
    Last Post: 28th July 2011, 21:51
  4. hid bulbs can you change the type of bulb you have?
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 8th December 2008, 09:52
  5. Sidelight bulbs change.. how 2??...
    By Dwabo in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2008, 18:09
