Thread: heater fan noise
    Regular Member ian1401's Avatar
    May 2011
    Exeter
    Default heater fan noise
    my heater fan,s become very noisy on speeds 1,2,3, does anyone know what the cause is..
    Semi siezed motor bearing most probably. If the drain is blocked then water can gather around the motor. Pretty sure there is a how2 for it and how to oil it & clear the crud out the drain hole.
    EDIT - might be this one
    Feb 2011
    Selby
    On mine, the plastic fan was rubbing on the motor housing, as it had slipped down the shaft slightly (or the shaft had slipped due to worn bearings).
    Take the motor out and you'll be sure to spot the problem. It's a time consuming job, but not difficult. Remove the glove box (5 screws), remove the footwell duct (one screw and a wiggle), unplug the motor and resistor pack, remove resistor pack, undo fan housing (7 screws - two are very close to the floor at the back, so you'll need a flexible or very short screwdriver), then wiggle it through the bottom and out. Three small screws hold the motor into the housing.
    Took me about 30 minutes to get it out, and about 20 minutes to put it back after tapping the shaft with a small hammer so the fan didn't catch on the motor.
    Otherwise - as said in the post above, if water's got in because of blocked drain holes, the motor bearings might be corroded and in need of lubrication.
    S.Shields (Newcastle)
    mine squeeks on speed 1 !!! super anoying!
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    interesting info, the wife's does this and figured it had to be something like this.. will be added it to my list of jobs while off over chrimbo.
    May 2011
    Exeter
    thanks for the info,i.ll have to have a look over the weekend
  1. Clicking noise when turning the heater dial
    By AntSSSS in forum Electrical & ICE (including SatNav)
    Last Post: 4th May 2013, 20:33
  2. Ticking noise from heater
    By conman in forum Electrical & ICE (including SatNav)
    Last Post: 2nd January 2013, 15:04
  3. Heater clicking noise again
    By Bamber in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd July 2012, 22:40
  4. heater fan noise
    By ian1401 in forum Electrical & ICE (including SatNav)
    Last Post: 10th December 2011, 13:40
  5. Heater blower noise???
    By stuart813 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd June 2010, 21:09
vectra heating fan noisy
vectra c heater blower noise
