Thread: lumpy idle 2.0 turbo
    Nov 2011
    manchester
    Default lumpy idle 2.0 turbo
    Hope everyone's well. Thanks for looking i have a 05 2.0 turbo only had the car a few weeks still gettin used to it , what i have noticed though is when the car is ideling it runs lumpy maybe thought plugs any ideas thanks terry
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    Give it a good service mate, plugs, leads, fuel and air filter are easily do-able yourself
    Worksop
    mine used to do it new plugs etc will sort it mine were due to a leaking flexi
    Nov 2011
    manchester
    thanks for that fella's will be on to it asap all the best terry
    Nov 2011
    manchester
    next question is there any gains over standard plugs and leads as to performance
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    there are no other 'lead' options, most owners use the standard plugs.. some use Denso Iridium, I use another type but my engine has lots of modifications and is highly tuned..
    Nov 2011
    manchester
    so you think standard plugs and leads then nige
    Jun 2009
    South Coast
    You will do as well with standard plugs. Leads, this refers to old distributer systems you have individual coils for each cylinder and its these coils that may cause you a misfire issue when they start to wear out. But as stated give it a good service first. Once you have done that then we can work on further steps if you still have issues.
    Nov 2011
    manchester
    thanks nige will get on with it asap all the best terry
  1. sri cdti 150 lumpy idle/ low mpg?
    By stevesri in forum Vectra C / Signum Car Chat
    Last Post: 10th February 2013, 20:39
  2. 3.2 lumpy idle update
    By DSmiddy in forum Engine & Drivetrain
    Last Post: 9th August 2011, 14:59
  3. Lumpy idle on 2.2 Direct SRi
    By Palmo in forum Engine & Drivetrain
    Last Post: 22nd January 2009, 18:53
  4. lumpy idle
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2008, 20:39
  5. 3.2 v6 Lumpy idle!?!
    By byebyeitsagsi in forum Engine & Drivetrain
    Last Post: 13th August 2008, 12:24
vectra sri 2.0 lumpy
vectra sri turbo tickover
