My vectra CDTi 150; when the ignition is switch on it remains on when it use to go out.
After the engine has started it goes out.
Any ideas?
Any ideas?
There's an "old" code stored. It'll just need resetting with a hand-held scanner
as above... nothing to worry about, unless the fault re occurs, it will sort itself out
Its only just started appearing though in the last few hours
as long as it goes out once the engine has fired, no need to worry
same here mine does that too! had it plugged in showed garage dude it etc and came up with nothing, look in manual it says i can be all sorts but i done all and still on lol just used to it now and im pretty sure in the vauxhall manual it says if it comes and and goes off ignore it, see for urself
Mine has only recently started staying on till after the engine with the last 24 hours.
QUESTION:
Why would it it only just started doing it?
Because the weather has got colder??
As the car is a Diesel, it might be one, or more, Glow Plugs not working.
They can be checked using a Multimeter, or the fault will show up on a code reader.
if it starts to stay on all the time , try looking at the diesel filter unit. could be getting a little wet in there if the rubber has perished.
my stayed on as the chip box i had on ( blew the ground terminal ) on the fuel unit where it warms the diesel up before starting.
On my car its normally the EGR valve starting to block up.
