Results 1 to 10 of 21
Thread: Spanner light staying on
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Default Spanner light staying on
    My vectra CDTi 150; when the ignition is switch on it remains on when it use to go out.
    After the engine has started it goes out.
    Any ideas?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    There's an "old" code stored. It'll just need resetting with a hand-held scanner
    West
    as above... nothing to worry about, unless the fault re occurs, it will sort itself out
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Its only just started appearing though in the last few hours
    West
    as long as it goes out once the engine has fired, no need to worry
    May 2008
    hartlepool
    same here mine does that too! had it plugged in showed garage dude it etc and came up with nothing, look in manual it says i can be all sorts but i done all and still on lol just used to it now and im pretty sure in the vauxhall manual it says if it comes and and goes off ignore it, see for urself
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Mine has only recently started staying on till after the engine with the last 24 hours.
    QUESTION:
    Why would it it only just started doing it?
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    Because the weather has got colder??
    As the car is a Diesel, it might be one, or more, Glow Plugs not working.
    They can be checked using a Multimeter, or the fault will show up on a code reader.
    Regular Member G4GAV's Avatar
    Bristol
    if it starts to stay on all the time , try looking at the diesel filter unit. could be getting a little wet in there if the rubber has perished.
    my stayed on as the chip box i had on ( blew the ground terminal ) on the fuel unit where it warms the diesel up before starting.
    Regular Member colalowe's Avatar
    in the North
    On my car its normally the EGR valve starting to block up.
  1. Airbag Light staying on
    By nigelminiowner in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2012, 20:51
  2. Oil light staying on
    By Jamesie82 in forum Engine & Drivetrain
    Last Post: 12th May 2012, 22:31
  3. Indicatopr Light Staying On?????
    By lubo_tl in forum Electrical & ICE (including SatNav)
    Last Post: 16th February 2012, 21:27
  4. TC and ABS light staying on?
    By JonSRi150 in forum Engine & Drivetrain
    Last Post: 31st December 2009, 22:10
  5. Battery light staying on
    By roukel01 in forum Electrical & ICE (including SatNav)
    Last Post: 13th August 2007, 08:17
