Results 1 to 10 of 11
Thread: Heated seat question
    Nov 2010
    Maidstone
    Default Heated seat question
    Having fitted the leather, ive just had the switches delivered and plugged in, all light up with ignition and turned on, i was sitting on drivers and tht seat warmed up, turned on passenger and not much seemed to happen, does the heated seats work in connection with seat occupancy? Many thanks
    Full Member Big Sig's Avatar
    Can't you sit in it and try it? You would have found out by now
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    I find my heated seats get warm when not turned on, but appear to get warmer when you sit in them
    Nov 2010
    Maidstone
    Didnt have a great deal of time to 'sit' about lol, not with a littlun yankin at ya ankles lol, will see if i can drive to work tomoz on the othe side lol
    Nov 2010
    North Yorkshire
    Vehicle : Signum Elite 1.9 CDTI
    Engine : 1.9 (150)
    Mileage : 113.000
    Just a quicky on the heated seats. I assume that switch position 1 is the lowest setting and 3 the highest and if they are not working as they should have they a fault code?
    Slough
    90 Post(s)
    Vehicle : insignia vxr
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    Quote Originally Posted by alhambra View Post
    right 1low 3 high . they both should work ,i take it you have the engine running when you have them on . i find that mine take a couple off mins to start getting warm ,then i have to turn mine off as they get to warm for me . . im lucky that ive now got them in the back and my daughter and friend both get warm bums on the way to collage . the back ones dont have 1-3 they just have on /off , also they dont get as warm as the front ones do . khalid
    the vectra has gone , but not far away so ill still see it form time to time
    Full Member
    South West
    i thought much the same when i had mine done, put the passenger side on and with just putting a hand on it to see if it warmed up didnt give off much heat.
    When you sit in it, the foam compresses and the heat from the pad then quickly passes through making it toasty!
    Regular Member bigcarman79's Avatar
    Jan 2008
    Pontefract
    3 settings???? Im sure my Elite had 5 settings!!
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    My elite has 3 settings
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Don't forget the half settings which give you 6 (might be 5 as I can't remeber if there is a first 1/2) well its does on mine.
  1. Replies: 42
    Last Post: 1st April 2012, 16:03
  2. Heated seat switches question
    By RBH in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2012, 23:01
  3. heated seat switches? also electric seat adjust questions?
    By big rich in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2010, 11:48
  4. Heated seat help!
    By lukesignum in forum Bodywork & Interior
    Last Post: 22nd January 2010, 18:13
  5. TC alarm and heated seat swiches Question
    By m300raj in forum Electrical & ICE (including SatNav)
    Last Post: 12th December 2009, 14:44
