Thread: Sub Box Help
    Regular Member CraigoT's Avatar
    York
    Default Sub Box Help
    i recently got a set of 2 12" subs and it says in the box then need 3-4 cu.ft the box i got with them only has about 2.2
    Will it be ok in the box? if not what should i do just build a extra box on the side?
    Regular Member ben_3.0v6's Avatar
    Apr 2011
    EMEC #3
    It'll be ok just you won't be getting the best from your system so could be an idea to only use one get a ported box built and sell the other one on as a decent single box will work just as well if not better on the lower notes. after all its what your bought a sub for to feel the lower notes.
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Year : 2010
    Mileage : 53000
    If it was me i would try to get the data sheet for the sub and build it to spec, Best doing it properly.
    York
    Quote Originally Posted by cliomjh 102 View Post
    well on the website it says 1.5 cu.ft for tight sound or 2 cu.ft for deep and then just double for 2, so i might just cut the back off the box iv got and add on what i need to make it the right size
    Regular Member mickydoos's Avatar
    Aug 2009
    Crawley, West Sussex
    Each sub should have its own chamber so you'd be best building/buying a new box. What subs are they mate?
    York
    Yeah the box iv got now has got wood in the middle to split them up. Fli frequency 12" or something like that I think
    Regular Member mcpitman's Avatar
    May 2011
    Derby
    Trim : Club
    Engine : 1.9 CDTi
    Just a quick thought, and I may well be incorrect, but fli are part of vibe. Vibe stands for Vented Innovative Bass Engineering. Stick em both in a vented box and add a bass cube or other tuning device & robert's your mothers brother....
