Results 1 to 10 of 18
Thread: V6 CDTi tyre pressures?
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Default V6 CDTi tyre pressures?
    I'm confused . Running 215/50-17 XL Kumho KU39's.
    The owner's book in the car says 39psi front and rear (which I'm running at the moment), some websites say 32 psi all round and m8Internet suggests 38psi up front and 35psi in the rears.
    So what do you guys reckon?
    Also, on the odd occasion I tow 1.5 tons on the rear, what would you do with the pressures then?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    i ave 38 all round on my vec when im on my own.
    however the other week i had 5 off us, and boot full of bags, so bumped the rear pressures upto 44 and the fron to 40.
    Quote Originally Posted by gtr1000 View Post
    This is an error and assumes standard tyres fitted
    The dealership I use kept lowering the tyre pressures, until I told then to stop doing so and showed them the handbook
    It turned out they were using the tyre pressures for the 1.9CDTI as the 3.0 V6 CDTI was not listed
    With 32 on the front then you will most likely suffer excess wear on both outside edges of the tyres (under inflation)
    With 38 you will suffer some slight excess wear in the centre of the tyre, but it is minimal in comparison
    I have been running 225/45R17 for a long time now and can tell when the tyres have been underinflated, below 35, on the front
    The handbook I have is for 2004 and applies to the Y30DT 3.0 V6 CDTI
    Take a look at the rear cover for the handbook version
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Even more confused now ........
    Just looked at a VX owners manual download for the Z30Dt from the Vauxhall site and yes, they give 38F, 35R.
    So why the difference between the Y30Dt @ 39psi F & R and the Z30DT?
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Sorry, just looked at the manual that's in the car and it's April 2003. Looks like somewhere between April 2003 and ?? 2004, VX revised the tyre pressures.
    i looked at the 2011 autodata chart at the tyre fitters and it said 39 psi all round
    It won't make much difference between 38 and 39
    215 50 R17 should be 38 at the front
    225 45 R17 should be 39 at the front
    VX probably simplified this from Z30DT and made them both 39
    39 on the rear is just a little too high, which will result in some excessive wear in the centre
    When towing refer to the laden load pressures, never had to use these myself, but I would expect these to be around 44
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    But 4psi on the rears (39/35) is quiet a difference?
    Yes, submit a request to VX for the correct tyre pressures for your car
    You may find that is correct for a Signum rather than a Vectra C (I assume the handbooks are different as mine doesn't have any Signum features in it)
    Regular Member omega63's Avatar
    Jul 2010
    Droylsden, Manchester
    5 Post(s)
    Vehicle : Insignia 2.0L CDTI SRI hatchback
    Trim : Black leather
    Engine : A20 DTJ 128 HP
    Mileage : 126,000
    Tyre Pressures Vectra-C - Model Year 2006 to 2008
    Note: If checking the tyre pressures manually with a tyre pressure tester ensure that the test connection is placed straight on the metal stems and without applying a great deal of pressure to avoid damage.
    In vehicles with a tyre pressure monitoring system, each time a manual pressure check is undertaken, first of all the valve adapter must be screwed on to the valve to prevent damage to the aluminium body.
    Use a valve cap wrench to release the valve cap more easily. It is located on the inside of the fuel tank flap. Vehicles with a tyre pressure monitoring system have an adapter in the valve cap wrench.
    Vehicle Type Engine [MY 2006 to 2008]
    Tyre designation
    Tyre pressure in kPa (bar) for load of up to 3 persons.
    Rim
    Snow chains
    Disc wheel
    ET
    Permissible
    Vectra-C saloon
    front
    rear
    front
    rear
    Z 16 XE, Z 16 XEP, Z 18 XE, Z 18 XEL
    195/65 R 15-91 H
    200 (2.0)
    220 (2.2)
    6 1/2 Jx15
    35
    yes
    no
    205/55 R 16-91 H
    6 1/2 Jx16
    41
    215/55 R 16-93 H
    215/50 R 17-91 W
    7 Jx17
    no
    225/45 R 17-91 W
    yes
    225/45 R 18-91 V1)
    7 1/2 Jx18
    no
    Z 18 XER
    195/65 R 15-91 V
    200 (2.0)
    220 (2.2)
    6 1/2 Jx15
    35
    yes
    no
    205/55 R 16-91 V
    6 1/2 Jx16
    41
    215/55 R 16-93 V
    215/50 R 17-91 W
    7 Jx17
    no
    225/45 R 17-91 W
    yes
    225/45 R 18-91 W 1)
    7 1/2 Jx18
    no
    Z 20 NET
    215/55 R 16-93 V
    230 (2.3)
    230 (2.3)
    6 1/2 Jx16
    41
    yes
    no
    215/50 R 17-91 W
    7 Jx17
    no
    225/45 R 17-91 W
    yes
    225/45 R 18-91 W 1)
    7 1/2 Jx18
    no
    205/55 R 16-91 (winter)
    240 (2.4)
    240 (2.4)
    6 1/2 Jx16
    yes
    Z 22 SE, Z 22 YH
    195/65 R 15-91 V
    230 (2.3)
    230 (2.3)
    6 1/2 Jx15
    35
    yes
    no
    205/55 R 16-91 V
    6 1/2 Jx16
    41
    215/55 R 16-93 V
    220 (2.2)
    220 (2.2)
    215/50 R 17-91 W
    7 Jx17
    no
    225/45 R 17-91 W
    yes
    225/45 R 18-91 W 1)
    7 1/2 Jx18
    no
    Z 28 NEL MT, Z 28 NET MT
    215/55 R 16-93 W
    240 (2.4)
    240 (2.4)
    6 1/2 Jx16
    412)
    yes
    no
    215/50 R 17-91 W
    260 (2.6)
    7 Jx17
    no
    225/45 R 17-91 W
    yes
    225/45 R 18-91 W 1)
    7 1/2 Jx18
    no
    Z 28 NEL AT, Z 28 NET AT
    215/55 R 16-93 W
    250 (2.5)
    230 (2.3)
    6 1/2 Jx16
    412)
    yes
    no
    215/50 R 17-91 W
    270 (2.7)
    240 (2.4)
    7 Jx17
    no
    225/45 R 17-91 W
    yes
    225/45 R 18-91 W 1)
    7 1/2 Jx18
    no
    Z 19 DTH
    195/65 R 15-91 V
    240 (2.4)
    240 (2.4)
    6 1/2 Jx15
    35
    yes
    no
    205/55 R 16-91 V
    6 1/2 Jx16
    41
    215/55 R 16-93 V
    230 (2.3)
    230 (2.3)
    215/50 R 17-91 W
    7 Jx17
    no
    225/45 R 17-91 W
    yes
    225/45 R 18-91 W 1)
    7 1/2 Jx18
    no
    Z 19 DT, Z 19 DTL
    195/65 R 15-91 H
    230 (2.3)
    230 (2.3)
    6 1/2 Jx15
    35
    yes
    no
    205/55 R 16-91 H
    6 1/2 Jx16
    41
    215/55 R 16-93 H
    220 (2.2)
    220 (2.2)
    215/50 R 17-91 W
    7 Jx17
    no
    225/45 R 17-91 W
    yes
    225/45 R 18-91 W 1)
    7 1/2 Jx18
    no
    Z 30 DT
    215/55 R 16-93 V
    250 ( 2.5)
    230 (2.3)
    6 1/2 Jx16
    41
    yes
    no
    215/50 R 17-95 W
    260 (2.6)
    240 (2.4)
    7 Jx17
    no
    225/45 R 18-95 W1)
    7 1/2 Jx18
    225/45 R 17-94 W
    270 (2.7)
    7 Jx17
    yes
    Tyre designation
    Rim
    Snow chains
    Disc wheel
    ET
    Permissible
    Vectra-C estate
    front
    rear
    front
    rear
    Z 18 XE, Z 18 XER
    195/65 R 15-91 H
    200 (2.0)
    220 (2.2)
    6 1/2 Jx15
    35
    yes
    no
    205/55 R 16-91 H
    6 1/2 Jx16
    41
    215/55 R 16-93 H
    215/50 R 17-91 W
    7 Jx17
    no
    225/45 R 17-91 W
    yes
    225/45 R 18-91 W 1)
    7 1/2 Jx18
    no
    Z 20 NET
    215/55 R 16-93 V
    230 (2.3)
    230 (2.3)
    6 1/2 Jx16
    41
    yes
    no
    215/50 R 17-91 W
    7 Jx17
    no
    225/45 R 17-91 W
    yes
    225/45 R 18-91 W 1)
    7 1/2 Jx18
    no
    240 (2.4)
    240 (2.4)
    6 1/2 Jx16
    yes
    Z 22 YH
    205/55 R 16-91 V
    230 (2.3)
    230 (2.3)
    6 1/2 Jx16
    41
    yes
    no
    215/55 R 16-93 V
    220 (2.2)
    220 (2.2)
    215/50 R 17-91 W
    7 Jx17
    no
    225/45 R 17-91 W
    yes
    225/45 R 18-91 W 1)
    7 1/2 Jx18
    no
    195/65 R 15-91 (winter)
    230 (2.3)
    230 (2.3)
    6 1/2 Jx15
    35
    yes
    215/55 R 16-93 W
    250 (2.5)
    230 (2.3)
    6 1/2 Jx16
    412)
    yes
    no
    215/50 R 17-91 W
    270 (2.7)
    240 (2.4)
    7 Jx17
    no
    225/45 R 17-91 W
    yes
    225/45 R 18-91 W 1)
    7 1/2 Jx18
    no
    215/55 R 16-93 W
    260 (2.6)
    240 (2.4)
    6 1/2 Jx16
    412)
    yes
    no
    215/50 R 17-91 W
    270 (2.7)
    7 Jx17
    no
    225/45 R 17-91 W
    280 (2.8)
    250 (2.5)
    yes
    225/45 R 18-91 W
    270 (2.7)
    240 (2.4)
    7 1/2 Jx18
    no
    Z 19 DTH
    195/65 R 15-91 H
    240 (2.4)
    240 (2.4)
    6 1/2 Jx15
    35
    yes
    no
    205/55 R 16-91 H
    6 1/2 Jx16
    41
    215/55 R 16-93 H
    230 (2.3)
    230 (2.3)
    215/50 R 17-91 W
    7 Jx17
    no
    225/45 R 17-91 W
    yes
    225/45 R 18-91 W 1)
    7 1/2 Jx18
    no
    Z 19 DT, Z 19 DTL
    195/65 R 15-91 H
    230 (2.3)
    230 (2.3)
    6 1/2 Jx15
    35
    yes
    no
    205/55 R 16-91 H
    6 1/2 Jx16
    41
    215/55 R 16-93 H
    220 (2.2)
    220 (2.2)
    215/50 R 17-91 W
    7 Jx17
    no
    225/45 R 17-91 W
    yes
    225/45 R 18-91 W 1)
    7 1/2 Jx18
    no
    Z 30 DT
    215/55 R 16-93 V
    250 (2.5)
    230 (2.3)
    6 1/2 Jx16
    41
    yes
    no
    215/50 R 17-95 W
    260 (2.6)
    240 (2.4)
    7 Jx17
    no
    225/45 R 18-95 W1)
    7 1/2 Jx18
    225/45 R 17-94 W
    270 (2.7)
    7 Jx17
    yes
    Emergency wheel
    T 115/70 R 16
    420 (4.2)
    420 (4.2)
    4 Jx16
    41
    no
    no
    Tyre designation
    Rim
    Snow chains
    Disc wheel
    ET
    Permissible
    Vectra-C saloon, estate with 19 inch rims
    front
    rear
    front
    rear
    Z 16 XE, Z 18 XE, Z 18 XEL, Z 18 XER, Z 20 NET, Z 22 SE, Z 22 YH, Z 19 DT, Z 19 DTL, Z 19 DTH
    235/35 R 19-91 W1)
    270 (2.7)
    240 (2.4)
    8 Jx19
    43
    no
    no
    215/55 R 16-93 (winter)
    230 (2.3)
    230 (2.3)
    6 1/2 Jx16
    41
    yes
    225/45 R 17-91 (winter)
    7 Jx17
    Z 28 NEL, Z 28 NET
    235/35 R 19-91 Y1)
    290 (2.9)
    260 (2.6)
    8 Jx19
    43
    no
    no
    235/40 R 18-95 W1)
    8 Jx18
    39
    215/35 R 16-93 (winter)
    280 (2.8)
    250 (2.5)
    6 1/2 Jx16
    412)
    yes
    7 Jx17
    Z 30 DT MT
    235/35 R 19-91 Y
    290 (2.9)
    260 (2.6)
    8 Jx19
    43
    no
    no
    270 (2.7)
    240 (2.4)
    6 1/2 Jx16
    41
    yes
    7 Jx17
    Z 30 DT AT
    235/35 R 19-91 Y
    290 (2.9)
    260 (2.6)
    8 Jx19
    43
    no
    no
    270 (2.7)
    250 (2.5)
    6 1/2 Jx16
    41
    yes
    7 Jx17
    Emergency wheel
    T 115/70 R 16
    420 (4.2)
    420 (4.2)
    4 Jx16
    41
    no
    no
    Only possible with subsequent conversion:
    Z 30 DT MT3)
    235/35 R 19-91 Y1) 3)
    290 (2.9)
    260 (2.6)
    8 Jx19
    43
    no
    no
    270 (2.7)
    240 (2.4)
    6 1/2 Jx16
    41
    yes
    7 Jx17
    Z 30 DT AT3)
    290 (2.9)
    260 (2.6)
    8 Jx19
    43
    no
    no
    270 (2.7)
    250 (2.5)
    6 1/2 Jx16
    41
    yes
    7 Jx17
    Note: Police vehicles (XJ1) with Z 19 DT and Z 19 DTH engines, all transmission versions, combined with 16" brakes are fitted with 16x6.5" wheels.
    1) Only for vehicles with sports suspension.
    2) The Vectra-C OPC with 225/45 R 17-91 requires a 7 Jx17 ET 39 rim.
    3) The 19" wheels are not factory-fitted to vehicles with Y 30 DT engine. On subsequent conversion, the specified tyre pressures must be set.
  1. Tyre pressures 1.9 cdti 120 16"
    By mcpitman in forum Suspension, Wheels & Brakes
    Last Post: 14th December 2011, 02:11
  2. tyre pressures v6 cdti please
    By woodze in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2010, 20:29
  3. Track Use Tyre Pressures and Tyre Temperatures
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2009, 23:04
  4. tyre pressures - cdti sri
    By tom_p_2000 in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2009, 22:21
  5. Tyre pressures for 215/50/17's on a 1.9 cdti 150 2005/05 please??
    By merikiito in forum Suspension, Wheels & Brakes
    Last Post: 21st February 2008, 19:27
tyre pressure for vectra c z30dt
whats the correct psi for a 22545r17 tyre on a vectra c
where are 6 12 JX17 ET
93v pressure vectra c
vectra c tyre pressures
