Thread: Intermittant Brake Warning
    Regular Member Bigglesfliesundone's Avatar
    Jun 2011
    Darlaston
    Default Intermittant Brake Warning
    Hi,
    I'm having an intermittant hand brake/brake warning light come on, but generally only around LH corners then it goes out on a RH corner!
    No brakes binding, no smell of hot brakes, no noticeable loss of performance, no noticeable increase in fuel consumption and it doesnt pull to either side!
    Vectra C 2.2 Dti on a 52 plate, new pads and discs all round a few months ago.
    Any ideas?
    BFU
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Try the earth wire underneath the handbrake lever. Its probably loose
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Check the brake fluid level fella
    11 Post(s)
    The warning light isn't only for the handbrake - it's also to indicate low brake fluid.
    Jun 2011
    Darlaston
    Cool, many thanks
    If its low is it a 4 dot or 3 dot?
    Thanks in advance
    Are you VXR Enough
    13 Post(s)
    Prob 4 or 5 dot
    Jun 2011
    Darlaston
    Thanks everyone, I love this board!!!!!!!!!!
    Are you VXR Enough
    13 Post(s)
    It's cool isnt it !!
    Jun 2011
    Darlaston
    Many thanks, all sorted, brake fluid was on MIN so topped up and no more sloshing!!!
    Thanks again
    Devon
    You now need to look into why the brake fluid has been allowed to drop to such a low level. Are the pads severely worn or is there a leak somewhere. Where there are symptoms there is always a cause!
  1. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  2. Brake Pad warning sensor
    By tutfut01 in forum Detailing and Car Care Discussion
    Last Post: 15th September 2010, 14:47
  3. Brake warning light
    By dandsi in forum Suspension, Wheels & Brakes
    Last Post: 9th January 2010, 16:32
  4. Brake pad warning light.....
    By axelf in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2009, 19:00
  5. Brake Pad Warning Light
    By nufckev in forum Vectra C / Signum Car Chat
    Last Post: 25th June 2008, 13:35
