Results 1 to 10 of 14
Thread: Battery gone.. Already :s
    Regular Member Shogun's Avatar
    Aug 2011
    Default Battery gone.. Already :s
    I say already cause this is my first experience with a diesel, it could be normal for all I know,
    Basically took my signum to ATS for a full service and they did their checks etc
    And said my battery's on its way out (it has been taking longer to get going on cold mornings)
    The cars 06 reg done 60k, 150cdti, anyone else had anything similar?
    Also apparently one of my front springs is snapped quoted me 220 to fix both front and tracking, plus battery at around 80
    And a tyre is going a funny shape too.. 100 quid
    Plus my service that will be around 600 in a week merry xmas
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    id get a second opinon fella as that sounds very expensive
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    600 for a service??? What the hell ate they changing?
    Are you VXR Enough
    13 Post(s)
    600 is for a battery 2front springs tracking 1 tyre and a service still expensive thou
    11 Post(s)
    Vauxhall will sell you a battery cheaperthan that - and with a 3 yr guarantee, IIRC.
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    I expect a battery to last 4 years, after that, plan for it going. If yours is the originaaaaaal, it's done well. Springs, well, known problem. Probably caused the tyre and tracking problem. Unfortunate this time of year. No way you can get car under cover and change items yourself, then get tracking checked?
    Aug 2011
    Thx boys yeah it will end up being around 600, with full service in on that as well
    Was a bit shocked at the battery going but I've learned recently diesels use the battery's more etc,
    I need my car every day for work tho with no alternative so just gunna let them do it on Friday,
    You guys think I'll be ok driving with the cracked spring, apparently its at the top if that makes any difference,
    And then just hope the battery doesn't conk out
    Pretty gutted really but can't blame the car cos its just generic stuff
    Aug 2011
    Regular Member signumboy's Avatar
    Edinburgh/outskirts
    Engine : 2.0 Ltr Turbo
    Mileage : 38000
    Mine lasted just over 3 years and the motor had no more than 20k miles on it i was told that Vauxhall stock pile their batteries not sure how true it was but your battery could be months or years before you even get it
    Nottingham
    Still got original battery on my 6 y.o. vectra. Not sure how much longer it will last. Had 3 of the springs replaced so far. Think the last one was about £70.
    Sent from my Desire HD using Tapatalk
  1. battery wiring block next to battery 150tdci - HELP
    By jameslunt in forum Electrical & ICE (including SatNav)
    Last Post: 2nd July 2012, 07:19
  2. Key fob battery
    By Fausty in forum Electrical & ICE (including SatNav)
    Last Post: 23rd December 2011, 02:38
  3. Battery
    By Wolfie01 in forum Electrical & ICE (including SatNav)
    Last Post: 7th December 2011, 23:52
  4. Battery Light ON - 14.1 volts at battery
    By snapsnap in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2011, 13:55
  5. Battery light on, 14.4V at the battery!
    By Saulty in forum Electrical & ICE (including SatNav)
    Last Post: 16th January 2011, 23:29
