Thread: Stiff steering.
    Regular Member andy-j's Avatar
    Apr 2008
    stoke on trent
    Default Stiff steering.
    Hi, I've got an 06 vectra 1.9cdti. The problem I've got is when cold and for about the first 10 miles the steering goes very stiff in the straight ahead position, it seems as though the power steering has gone but with a lot of pressure applied it turns about 20 degrees then the power kicks back in and the wheel turns as normal. This only happens when cold and in the straight ahead position.
    Any ideas please, its driving me mad.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Check the power steering fluid level, sounds like it might be a little low and taking a bit of time to fill the rack up properly. Alternatively you may have alternator issues as the power steering on the Vec is electro-hydraulic.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    as Ian siad check your power steering fluid level and get the alternator voltage checked and you shouldnt be driving it like that fella could be very dangerous
    Apr 2008
    stoke on trent
    Alternator and fluid fine. This morning I left the car running for 30 mins before driving due to ice and when I drove off the steering was perfect, so looks like that's the answer waste diesel.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    The power steering pump is the next port of call then m8. Pray it ain't that, they ain't cheap. Don't drive a car where the steering is impaired.
  1. stiff gears
    By nicj in forum Engine & Drivetrain
    Last Post: 4th November 2011, 14:30
  2. Stiff power steering after 10 mins of driving
    By jrwilshire2003 in forum Suspension, Wheels & Brakes
    Last Post: 22nd February 2010, 21:30
  3. Stiff gear changes
    By James7 in forum Engine & Drivetrain
    Last Post: 17th April 2007, 19:45
  4. Stiff gearchange
    By monkeybusiness in forum Engine & Drivetrain
    Last Post: 19th January 2007, 18:58
  5. Bored stiff.
    By R-man in forum General Chat
    Last Post: 12th February 2006, 22:14
vauxhall vectra 2008 power steering really stiff
zafira cdti sticky steering
vectra c stiff power steering
