Thread: battery info
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default battery info
    other day my battery went flat after trying to start the car when air was in the fuel system,
    so i took the battery off and charged it, the indicator was black not green but when i moved the battery it went green because of the fluid inside like it was lo on fluid,
    its a standard vx battery do these batterys need topping up still? because it says on the battery no maintainance
    11 Post(s)
    They are classed as maintenance free - ie, no topping up required.
    However, inside the battery is a small reservoir and over the period of its life this reservoir automatically tops up the battery. Eventually though the reservoir becomes empty, the battery no longer gets topped up and it will fail one day.
    Not sure about batteries now, but with maintenance free batteries from a few years ago, if you looked carefully enough you could see where the reservoir was and prise off the cover to top it up - thus prolonging the life of the battery a couple more years. Sometimes you had to remove the manufacturers label to see where it was.
    The green indicator is not 100% reliable in telling you the health of the battery. It is just that, an indicator, and sometimes just a rough one.
    Oct 2009
    Sandwell
    yeah i can see the labels have covered up the holes, is it just deionised water that you top it up with?
    11 Post(s)
    Yep. Or clean rainwater that hasn't come into contact with anything metal.
  1. battery wiring block next to battery 150tdci - HELP
    By jameslunt in forum Electrical & ICE (including SatNav)
    Last Post: 2nd July 2012, 07:19
  2. Replacing Board Info Display (BID) with Color Info display (CID)
    By grigs1 in forum Electrical & ICE (including SatNav)
    Last Post: 11th April 2012, 22:13
  3. Battery Light ON - 14.1 volts at battery
    By snapsnap in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2011, 13:55
  4. Battery light on, 14.4V at the battery!
    By Saulty in forum Electrical & ICE (including SatNav)
    Last Post: 16th January 2011, 23:29
  5. Need Info..
    By boxer in forum Engine & Drivetrain
    Last Post: 7th September 2008, 17:43
