Results 1 to 10 of 14
Thread: AFL & ABS Warning Lights - Problem
    spoons
    Guest
    Default AFL & ABS Warning Lights - Problem
    Got a problem with the Vectra VXR over this weekend
    Symptoms are:-
    - AFL Warning Light Flashing on dash
    - ABS Warning Light static on dash
    - AFL Lights dont do self level check on start up
    - AFL Lights dont move left & right around corners
    - Indicators wont self cancel
    Any ideas guys?
    Glasgow
    Could be the CIM actually im pretty sure it will be the CIM, the AFL wont get the signal from the steering as wont the indicators and the ABS light is most likely not communicating because of that.
    Full Member spennny's Avatar
    Blantyre
    Could it be CIM related mate, maybe something to do with calibration as the indicators won't self cancel?
    Just a guess
    spoons
    Guest
    Thanks lads, I'm thinking the same thing...
    Can I pre-check any simple things first?
    - Like fuses? which ones should I check?
    - Like WD40? which connectors should I spray?
    etc.. just simple stuff first before I start spending money... again
    Blantyre
    U got a code reader ? Silly question I know but if there are symptoms like you say then there may be codes ?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Could be CIM but its more a failure of earlier prefacelift cars, but there seams to be loads of CIM related threads popping up this last week, wonder if its a cold and moisture thing?
    Linky to some checks here but as said for older cars.
    PS the ABS plug has been updated so really doubt its that, but you never know...
    Jun 2006
    St. Helens,Merseyside
    thats how my cim started
    afl's stopped moving left/right
    self cancel on indicators stopped
    airbag light on then back of a few times a day
    code was steering angle sensor out of calibration iirc
    spoons
    Guest
    Rushy thats excellent thanks.
    My ABS plug is right under my nearside bonnet vent. So that could have caused some water ingress? I did make an alloy cover plate for it, but maybe it hasnt worked.
    I'll go buy some electrical contact cleaner from Maplins today and try that first. Fingers crossed and will keep this thread updated
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Im about to go on my 3 CIM...
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    3rd cim !!!!!! I'd set fire to it lol
  1. warning lights
    By ian 1234 in forum Electrical & ICE (including SatNav)
    Last Post: 21st April 2012, 20:34
  2. ABS and ESP warning lights
    By ChristopheCDTI in forum Suspension, Wheels & Brakes
    Last Post: 4th October 2011, 17:13
  3. warning lights
    By ben2996 in forum Vectra C / Signum Troubleshooting
    Last Post: 31st January 2011, 17:09
  4. ABS and t/c warning lights
    By jossyboy in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2009, 17:36
  5. warning lights
    By lee_car in forum Vectra C / Signum Troubleshooting
    Last Post: 30th October 2008, 14:01
