Thread: 1.8 vvt gear change
    devon
    Default 1.8 vvt gear change
    can any one tell me if this is normal.However I try I cannot change from first gear to second smoothly.When I shut off to change gear the engine sometimes holds on to the revs.Changing from 3rd gear up is smooth.I do have some clutch judder but only when the car is cold but I dont think this is the problem
    Regular Member Wolflinn's Avatar
    Camberley
    No not normal m8
    Changing from 1st to 2nd should be smooth.
    The engine does hold on to the revs from time to time but that is mostly de-clutching in 1st something to do with a dump value (and is normal)
    devon
    Thanks.
    Sep 2009
    Audley STAFFS
    had a similar problem with my Vec When I first got it, air box mod and a new air filter sorted this
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2017, 03:14
  2. Gear box oil change
    By beat275 in forum Engine & Drivetrain
    Last Post: 8th January 2012, 12:12
  3. gear change
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 6th March 2010, 09:31
  4. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
  5. change gear
    By aptoman in forum Engine & Drivetrain
    Last Post: 3rd June 2008, 23:16
