Thread: 1.9 CDTi turbo not kicking in till 2400rpm
    Woodbridge
    Default 1.9 CDTi turbo not kicking in till 2400rpm
    Just wondering if any one has any ideas on this, it used to kick in around 1800RPM, but now its not till later. Only just noticed it as its on the wife's car and I only drove it today. It has done around 17000 miles since its last service but had an oil and filter a few 1000 miles ago.
    Any suggestions??
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Boost sensor dodgy
    Sodding Typical on Sea
    Check also the EGR operation, and vac pipes, but agree boost sensor may well need a good clean
    Woodbridge
    Quote Originally Posted by CritchvxD View Post
    Boost sensor dodgy
    Quote Originally Posted by Derek Mc View Post
    This was my initial thought. Is there anything else it could be? EGR was cleaned about 3 months ago.
    Woodbridge
    Anyone else?
    Aug 2009
    Wakefield
    You could try checking your air filter.... VX dont replace them at every service... eek! mine was feeling a little flat and when I checked the air filter it was heavily soiled and had started to deform the paper ridges in places... swapped it out for a new one and all better again...
    I've since swapped it for a K&N panel filter and the difference is noght and day....
  1. No boost until 2400RPM - CDTi 150
    By cont1204 in forum Engine & Drivetrain
    Last Post: 15th February 2013, 10:51
  2. car kicking out smoke
    By coooky in forum Engine & Drivetrain
    Last Post: 19th August 2011, 20:47
  3. 20k revs then kicking in to 30k
    By richje100 in forum Engine & Drivetrain
    Last Post: 27th April 2011, 16:43
  4. cdti turbo not kicking in
    By dawsinho in forum Engine & Drivetrain
    Last Post: 15th November 2009, 17:32
  5. I bet hes kicking himself now...
    By rob 2.2dti in forum Comedy & Humour
    Last Post: 10th February 2009, 20:09
