Thread: Replacing gear stick
    Nov 2010
    Maidstone
    Default Replacing gear stick
    Im about to replace the gearstick on the signum for the slightly shorter astra h version, but not sure how it all comes apart, on my old old mk3 astra it used to be just a pin but if anyone has any pics or a how to that would be great, many thanks.
    Quote Originally Posted by signum_rob View Post
    im sure that the whole unit is held in with bolts and then you just unclip the linkages
    South West
    It its the same as the vectra, take the gaitor off, 4x torx bolts undoes the cage around the stick, shouldnt need to undo the linkages, there is a ball joint at the bottom of the stick which thus connects to the linkages. Just use a long shaft flat head screw driver to pop off the ball out of the socket.
    exeter
    mine vectra c i had too strip the centre console and remove the whole cage with the stick . because mine was a complete unit and you can not take just the stick out. it depends on where your reverse is
    Nov 2010
    Maidstone
    My reverse is left and up, does this change things?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    I need to change mine from what I can see, it's a case of undoing the 4 torx bolts and releasing the ball joint so it shouldn't be that bad.
    exeter
    no your should be the easy one . if your reverse in right and down. it the whole unit. because it if you pull the ball joint out you can't get the new one back in . i even asked vx . i went and brought just the stick of ebay that someone rip out tried to fit it could'nt so i ask vx and they said its a sealed unit . so i went to my local scrapie's and took one out myself paid £15 and not to bad to fit about 3ish hours
  1. For Sale: vxr gear stick
    By happypostie in forum Parts for sale
    Last Post: 22nd January 2012, 20:17
  2. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  3. Gear stick
    By Vectra King in forum Vectra C / Signum Troubleshooting
    Last Post: 11th September 2010, 23:54
  4. Vec C 52 plate 2.2 Dti Gear Stick Jumps out of 1st gear on take off
    By ukwanderer01 in forum Engine & Drivetrain
    Last Post: 5th July 2009, 21:43
