Results 1 to 10 of 17
Thread: best performance spark plugs
    Regular Member beat275's Avatar
    Aug 2011
    Newcastle West Denton
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    confused best performance spark plugs
    as above for the 2.0t z20net thanks
    Regular Member disco dan's Avatar
    Apr 2011
    Southport
    I had a Z20 LET 2.0t and used NGK iridiums.
    Aug 2011
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    were they any good?
    Apr 2011
    Southport
    courtenay sport remapped it and insisted on them, 242bhp 265ft lb torque. I use them on my vec now.
    Aug 2011
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    mines is just standard dont want to buy them incase they mess my engine up
    Apr 2011
    Southport
    Im sure their nothing too special just a better replacement from standard ones.
    Aug 2011
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    what about the leads to the coil pack? any idea where i would get replacement think iv go somthing wrong with them
    Apr 2011
    Southport
    not 100% sure, you'd be better off talkin to someone on here with the same engine, but have you tried LMF Vauxhall? http://www.lmfvauxhall.co.uk/
    Regular Member Keif's Avatar
    In the Garage
    Loads on here about Spark Plugs for the Z20NET. I tried some others from the recommended NGK ones and it ran like a pig.
    Stick to the recommended ones - PFR6T-10G. In the Z20NET the ECU gives a small spark to all 4 spark plugs at once, to see which one allows high current to flow across the terminals of the spark plug - this tells it in which cylinder combustion is about to happen, and also whether knock is about to occur, (it doesn't have a separate knock sensor). So the plugs get more of a hammering than in many other engines.
    Taken from HERE
    They're cheap enough from eBay.
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    if your standard you probably best sticking with the standard plugs mentoned by Jezzy.. Some guys use Iridium plugs.. I have tried them all and now use Bio Fuel plugs on mine now...
    Coils are expensive from the dealers its best to buy used replacements from Neo Brothers as its much much cheaper.. I have replaced 3 now... are you getting misfire fault codes?
  1. Spark Plugs were wet
    By xoborp in forum Engine & Drivetrain
    Last Post: 7th January 2013, 21:59
  2. spark plugs
    By jimbo1987 in forum Engine & Drivetrain
    Last Post: 5th February 2012, 21:16
  3. Spark plugs
    By telstar in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2010, 20:36
  4. 2.0t spark plugs
    By SRI-RICH in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2008, 18:02
  5. 2.2P spark plugs 25 324 618
    By vectrasri03 in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2007, 15:53
