Results 1 to 10 of 16
Thread: No ignition
    May 2011
    sunderland
    Default No ignition
    Hi hope someone can help ive got a 1.9cdti vectra and when i turn the key nothing happens.lights ,radio,heaters all electrics ok but nothing from the engine apart from a tickin from the glovebox.it isnt a loud tickin so i dont think its the starter motor when i turned the key the heater blow stopped but when i released the key onto ignition only the blower came back on any help please
    morecambe
    43 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Battery mate
    May 2011
    sunderland
    Hi mate but surely if it was the battery all the other electrics wouldnt work ????
    morecambe
    43 Post(s)
    Vehicle : vectra
    Trim : vxr
    Nope battery honest mine did it the other day u not got enuf power in the battery trust me
    May 2011
    sunderland
    Ill try a new battery tomorrow the next thing is how do i find the security code for my radio thanks for advice mate
    11 Post(s)
    You won't need a code for the stereo unless you want to change either the stereo or the display unit or transfer it to another car.
    I concur that the battery is probably flat. Shouldn't have thought it needed changing yet though. Have you tried charging it first?
    May 2011
    sunderland
    Smile
    It starts when i bump start it but if i switch the engine off it still wont start unless i bump it. I have noticed it has been reluctant to start on a morning but i thought it was due to the cold weather but if the battery is dead as a dodo wouldnt the battery light come on the dash?? Thanks again lads top guys
    May 2011
    sunderland
    Or might it be that the alternator is packing up? Or would i loose all electrics eventually after a short period of time which i am not i can drive around for hours and still have all electrics thanks
    May 2011
    sunderland
    Or might it be the starter motor relay coz when i try and start it there is a clicking noise comin from behind the glovebox. Starts and runs fine after bump start
    11 Post(s)
    Quote Originally Posted by pud wayman View Post
    The light you're refering to is the alternator fault light, not the battery.
    A bump start followed by a little pootle down the road won't charge a flat battery. You wuld have to drive quite a few miles before putting a substantial charge back into it.
  1. 2.2 DTi ignition
    By aladino77 in forum Vectra C / Signum Troubleshooting
    Last Post: 5th June 2013, 10:28
  2. Ignition came off on the end of the key!
    By dukeminster in forum Vectra C / Signum Car Chat
    Last Post: 7th October 2008, 12:45
  3. ignition
    By raymond1711 in forum Engine & Drivetrain
    Last Post: 20th July 2008, 14:02
  4. Ignition
    By Marc 100 in forum Vectra C / Signum Car Chat
    Last Post: 11th June 2007, 20:21
  5. ignition +ve
    By abz007 in forum Electrical & ICE (including SatNav)
    Last Post: 14th January 2007, 12:22
