Thread: Po700
    Sep 2011
    Sipson
    Default Po700
    Saw a flicker of spanner when I pulled into the mother in laws today, then when I left it came on again and felt like in limp mode, but 600yds later the spanner disappeared and boost felt good again.
    I checked codes when I got home and have two pending faults, P0100 and P0101, and a actual fault P0700 which indicates ambient temperature wrong. So from that I assume just replacing the boost sensor (was cleaned 2 months ago so assuming is faulty not dirty) should get rid of that problem, and as a consequence, the pending faults.
    So question is, where on a Sunday can you get a boost sensor? No where I;m guessing.
    West
    Try another clean up 1st, remove the elbow & give that a right good clean too with carb cleaner
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    As you've mentioned "ambient air temperature", could it be the MAF sensor as this also measures air temp?
    Sep 2011
    Sipson
    Thanks DH, I was going to check if it needed cleaning again, was just assuming after only 2 months it shouldn't need it again.
    GTR1000, not sure, I thought the MAF just measure the airflow density/speed and the boost sensor measured air temp. But I'll go and have a look in a mo, just letting me breakfast go down.
    Sep 2011
    Sipson
    le double post
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Little bit of techy reading for the hot wire type MAF. http://www.sensorland.com/HowPage060.html
    Sep 2011
    Sipson
    thanks, but I still think its the MAP/Boost sensor as the associated codes are to do with the manifold, therefore as the MAP takes the temp in the inlet manifold I assume it is the boost sensor giving the wrong temp.
    Plus, I did take it out today, didn't look particularly at all, but I sprayed some WD on it, gave it a wipe and chucked it back in, cleared codes and went for a 10 mile drive, no repeat codes, but oddly the temp readings were still fluctuating from about 15-26C, which given the ambient this morning were about 9C I think, and the engine was cold, thats a big fluctuation, so I think I'll splash out on a new MAP sensor for now.
  1. PO700 Fault code
    By Wal2705 in forum Engine & Drivetrain
    Last Post: 3rd July 2012, 20:27
  2. Faultcodes Po175 Po700 Gear Box
    By stella in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2007, 22:57
p0700 opel defalt code
