Results 1 to 10 of 11
Thread: Brake squeal
    Regular Member Samdy Gray's Avatar
    Jul 2009
    Wiltshire, UK
    Default Brake squeal
    Bit of an odd one this and sorry for the long post.
    Started noticing a few weeks ago that the drivers side front wheel was squealing when the brake wasn't being applied. It would only do this once you'd driven a few miles, i.e. when the brakes got warm. As soon as I braked, the squeal stopped. I jacked the car up and tried to spin the wheel and it was stiff, therefore my first thought was that the caliper was sticking although I later found that when the brakes are cold the wheel spins freely. I checked the dust/crap guard and it definitely wasn't that catching on the disk. The drivers side front wheel was also slightly warmer than the passenger side.
    I didn't have time to look at it myself originally so took it to a mechanic who checked the caliper over, confirmed it was fine, cleaned it all up and applied some fresh copper grease and I went on my way. It was fine again for a few days until it started squealing again. Same symptoms, the noise goes away when I brake.
    So today myself and my step-dad had the caliper off again to see what the problem was. The caliper came off no problem and the piston retracted very easily, so it's definitely not that sticking. The problem we did find was that on the inner pad there was a heavy score on the bottom of the pad, about 2-3mm from the edge which had kind of left a V shape groove and a sharp edge of the bottom of the pad. From the look of it the pads have been overhanging the lip on the inner edge of the disk which has caused the scoring. So a grove has formed in the pad which appears to be binding onto the lip of the disk when they're hot.
    One thing that is puzzling me is if the lip of the disk has scored the pad, why has it only started squealing now and didn't do it from when they were first fitted?
    The pads were fitted by the place I bought the car from and it looks as though they either should've fitted new disks and didn't, or they've fitted the wrong sized pads (less likely I would've thought, if the lip wasn't there the pads would fit fine). I have found that the bottom edges of the pads are slightly chamfered, possibly done by the garage to make the pads fit over the lip on the disk.
    My temporary solution has been to file the sharp edge of the pad down to remove the groove. I haven't managed to drive the car long enough to get the brakes decently hot but the squeal has gone to an extent, it started doing it again a little which I'm guessing is because the lip has started to score the pad again so I'll give it a few days and it's bound to be squealing away again.
    What's best for me to do? Try and skim the lip of the disks (and possibly new pads as well), or just to (hopefully) eliminate the problem completely and replace pads and disks?
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    i would personally get new discs and pads to be safe. i'm having the same problem as you, and i'm getting all new discs and pads fitted next week.
    Jul 2009
    Wiltshire, UK
    That's what I'm probably going to do, but knowing my luck I'll fork out on that and it won't have cured the noise.
    Regular Member Jonsey's Avatar
    Oct 2010
    Walkden, Manchester
    I have got the same noise ever since fitting new GM disks and pads about 8mths ago, I put fresh grease on the pads about 4 weeks ago, was fine for about a week and half but its come back. Pressing the pedal stops it for about a mile then comes back, I have kinda given up on finding whats causing it tbh.
    Regular Member myelite150's Avatar
    Nov 2009
    south wales,Cwmbran
    Quote Originally Posted by Samdy Gray View Post
    athough there is a risk of not curing the noise ,i would always say you can never waste money on new brakes so even if it dont cure it you have brand new discs and pads that you would of needed anyway.
    just thinking of glass half full not half empty
    Jul 2009
    Wiltshire, UK
    A very good point. There's me, ever the pessimist!
    Managed to give it a bit more of a test on the drive to work this morning (13 miles), the squeal wasn't half as bad as it was before I filed the pad down so that seems to have pinpointed the problem. Looks like new pads & disks is what I need.
    Regular Member amand's Avatar
    Feb 2011
    west London
    i have to same problem too. i got mtec brake discs and pads fitted. they squeal after a few miles. when i move off in traffic it starts to squeal and its annoying. i now grooved and drilled discs make noise but not when im not pressing the brakes. if its a sticky caliper what is the cure to this problem?
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    New disks and pads fella u should never mess about with safety items like brakes
    Feb 2011
    west London
    You sure i just had mtec discs and mintex pads fitted in september. brand new as well, they can't have gone already. What do you reckon?
    they squeal when i move off and when driving at 30mph or so. only after a mile or so of driving
    Jul 2009
    Wiltshire, UK
    Back to pretty bad squealing this morning
    Looks like new pads and disks next week.
  1. Got Squeal ??
    By wardy23 in forum Suspension, Wheels & Brakes
    Last Post: 19th March 2012, 22:42
  2. NSF brake squeal and poss bind
    By Caveman_nige in forum Suspension, Wheels & Brakes
    Last Post: 11th October 2010, 19:10
  3. Brake Squeal
    By yoclick in forum Suspension, Wheels & Brakes
    Last Post: 17th August 2009, 19:32
  4. squeal
    By Guyver1 in forum Vectra C / Signum Car Chat
    Last Post: 1st December 2007, 20:57
  5. Rear Brake squeal.
    By rozzer1976 in forum Suspension, Wheels & Brakes
    Last Post: 10th September 2007, 06:58
